87 Trans Am.......GTA Style Interior?
Old Dec 24, 2011 | 04:08 PM
wwe442's Avatar
Car: Too many!
Hello, I recently bought an 87 Trans Am, but i noticed it has a GTA style interior, but its not a GTA. Was this a special package available? The owner told me the interior was rare but i know nothing about why it would be different. Any help would be greatly appreciated!
Old Dec 24, 2011 | 04:12 PM
wwe442's Avatar
Car: Too many!
Re: 87 Trans Am.......GTA Style Interior?
another thing is where could i find carpet and a new passenger seat for cheap? what do seats run for at a junkyard? the t-tops leaked and some of the interior got moldy. im on a budget and just want to make the car decent. thanks
Old Dec 24, 2011 | 06:24 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Pretty sure the GTA interior was an option on the lower models... I've seen a base model/Formula (don't know, as it was pretty stripped) at the J/Y with the interior and crank windows, and my base V6 has it factory...
Junkyard is probably your best bet for cheap interior as shipping isn't cheap...
Take out the carpet and spray the crap out of it with a decent amount of water pressure, say, the medium pressure setting on a pressure washer, and some degreaser. I can't even begin to describe the amount of crap that came out of my main carpet when I did that . I think I pressure-washed it for a solid HOUR. But still didn't get the heater core leak stain out . The mold and crap should come out easily with that, and then hit it with some Lysol or something to kill it dead.
You definitely want to remove the carpet anyways and then go to Home Depot or somewhere and get some new insulation/padding to lay down underneath, as the factory crap (it's the same stuff, can't find what I used anymore) is most likely even more moldy than the carpets. Anyways, you REALLY want to look for rust holes in the floor pan, especially in the rear corners by the back seats.
Old Dec 24, 2011 | 06:32 PM
JT's Avatar
JT
Community Administrator
The deluxe door panels, as well as the ultima seats, which were found on the GTA, were also available on the Trans AM.
Old Dec 24, 2011 | 08:06 PM
racerx520's Avatar
yup! and if you want to get rid of the deluxe door panels, ill take them from ya . provided they're gray in color
Old Dec 24, 2011 | 09:35 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
My 87 TA has the deluxe interior (in gray) and looks the same as my friends 88 GTA.
Old Dec 24, 2011 | 09:46 PM
wwe442's Avatar
Car: Too many!
i have a set of GTA panels from a GTA that came with the doors i bought, if i dont end up using them on this car maybe we can work a deal out.
Old Dec 25, 2011 | 03:29 PM
racerx520's Avatar
let me know! as long as theyre gray and in decent shape they should be fine for me. pm me if you are looking to get rid of them.
Old Dec 25, 2011 | 04:06 PM
wwe442's Avatar
Car: Too many!
there gray and there decent i believe. the one is still attached to the door (how do i get it off?!) ill pm you when i go to get rid of the spare set if i dont end up using them. thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
