Loose Steering Wheel
Old Jan 2, 2012 | 04:14 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
Transmission: Newly rebuilt 700R4
Had to replace ignition switch due to lost keys. Put everything back the way it was (at least all the parts), now my steering wheel is very loose! What the hell happened? Please Help.
I've searched under several keywords but i can't find this specific problem unless this is referred to as the Steering Column but this is the shaft that the steering wheel attaches to.
Old Jan 2, 2012 | 05:13 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Loose Steering Wheel
Did you torque the retaining nut to spec and replace the nut retainer?
JamesC
Old Jan 2, 2012 | 05:17 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
torqued it to spec 35lbs right?, there was no retainer when i removed it. Without the wheel on i can move the shaft in a circle with 2 fingers. There was always a little bit of movement, but very very slight, now it feels as if it could come off in my hands.
Old Jan 2, 2012 | 05:29 PM
JamesC's Avatar
Have you seen the following:
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
Old Jan 2, 2012 | 05:40 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
I have seen it, it helped a lot when i removed everything down to the ignition. Very cool!
I know almost nothing about steering columns though. I thought that was a different problem. Mine is, I can move the part the wheel attaches to in a circle with very little effort.
Old Jan 2, 2012 | 10:55 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
bump
Old Jan 2, 2012 | 10:58 PM
stereojnky's Avatar
Car: 1992 Rs
If you could post pictures, that would probably help.
Old Jan 2, 2012 | 11:12 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
Will put some up in the morning
Old Jan 3, 2012 | 10:27 AM
jameecrockettRS's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI (5.0L)
Transmission: 4 speed automatic
I have this same problem. Where the tilt steering pivots mine moves probably about 2 inches in any direction. I am selling mine thursday anyways, but would be nice to tell the purchaser what to do.
Old Jan 3, 2012 | 08:52 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
Found the problem and found out the parts are discontinued (imagine that). Apparently they slid out of place when i took everything apart and i didn't realize it. Had to go to the junk yard to get 'em.
Without pressure on the bearing that surrounds the steering shaft (from the 2 parts in the picture), the wheel felt like it could come off in your hands. Now it's tighter than it was before
Attached Thumbnails Loose Steering Wheel-fits-into-bearings.jpg   Loose Steering Wheel-part-placement.jpg   Loose Steering Wheel-special-k-steering-column
Old Jan 3, 2012 | 08:59 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Your steering column is a tilt column. When you tear it down, at the pivot point for the tilt there are 4 torx bolts that are notorious for coming loose. Tighten those bolts and you should be in good shape.
Old Jan 3, 2012 | 11:09 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
his problem is the upper column shaft bearing race and spring
not the four loose tilt column screws
the steering lock plate is also involved with upper column shaft bearing load and tightness also
need it to compress the sprign that loads the bearing and race to keep the upper shaft tight and therefore not have slop in this shaft which would therefore make the wheel be sloppy
the infamous four loose tilt screws makes for a different kind of sloppy column, down lower in the column, lower than where the upper shaft bearings are
Old Jan 8, 2012 | 11:28 AM
the blur's Avatar
When all else fails, send it out to a rebuilder.
Old Jan 8, 2012 | 11:37 AM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
Hah! That's me. Well, it is now anyway.
Old Jan 13, 2012 | 11:59 AM
fierolover's Avatar
if anyone wants this done in the sacramento area i do it for $30.
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
