Replacement dash pad
Old Jan 10, 2012 | 03:43 PM
IBrockZ's Avatar
Car: 87 irocz 305 5.0 5 speed G92 option
Engine: 305 tpi
Axle/Gears: 9 bolt 3.45 factory gears
So I know there are probably a lot of these posts but I feel like I havent gotten a solid answer from what I have researched on here...
So my question is who makes a better dash pad Hawks or Classic Industries? If you have one from either company can you post a pic so I can see the difference.
Also there is a crack on my center ac vent around the edge. What do people do about cracks in the dash? can you buy the whole dash reproduction or do you have to find one in the junk yards?
Old Jan 10, 2012 | 05:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Replacement dash pad
Personally,I think they all use the same manufacturer,Classic Knox your sox off for S/H I don't know what Hawks charges.
Old Jan 10, 2012 | 05:40 PM
IBrockZ's Avatar
Engine: 305 tpi
Do the repros look bad? Mine has been covered with vinyl not really a fan. I'm looking for a new dash too for my 87 iroc.
Old Feb 8, 2012 | 10:01 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
both suppliers sell the same part,ive heard.and the quality is not acceptable.i have seen the re pops they are not even as good as a used one.if you dont mind it not being "right" you might justify spending $400 plus
Old Feb 9, 2012 | 04:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
I checked out Hawks dash pads and they don't list who makes theirs,I checked out Classic Ind. and theirs is made by OER,who reproduces EXACT replacement dash pads for the TA,I don't know about the camaro,I didn't look, have to check later.OER is licensed by GM to produce these pads,so I'm guessing,only guessing that Classic's would be the better pad to purchase,I hope so,I have one on order, but it has been no stocked since I ordered one,the reason they gave me was it was out for research and development.Apparently they were having a fitment problem with the screw holes.
Old Feb 9, 2012 | 07:23 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
There is a place called Just dashes
They are not cheap, but they are perfect.
http://www.justdashes.com/
The other ones you are referencing are reproductions
I have "reupholstered" some, and they look good - but not like theirs !
Mine has double reinforced seam on the edge.
On my camaro I will not use the same speaker grille as factory.
Old Feb 9, 2012 | 07:41 PM
reefland's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L
I spoke to Camaro Central and they speak highly of their OER dash pad...
Old Feb 9, 2012 | 08:39 PM
Car: 86 IROC
Engine: 5.0 TPI
yeah theyre in R&D because 7 of 10 got sent back by the same people that were told "its a exact fit" .they are all made in china by someone that cant even say "camaro" and they may have bought a license from GM to produce them ,too bad GM didnt stipulate in the contract that theyre can not be any deviations in the blueprints. i would take a old cracked dash pad over theyre "OER" junk any day,at least itd fit with NO tweaking
Old Feb 9, 2012 | 08:44 PM
Car: 86 IROC
Engine: 5.0 TPI
that is because they want to sell you one,go take a look at the dash pad they are selling.i guess it would be funny except we expect to buy a genuine ,no mods ,matches the original in every way,dash pad.period
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
z28_AJ
Aug 27, 2015 08:59 PM
Vintageracer
Aug 11, 2015 08:13 PM
