Horn Doesn't Work?
Old Feb 14, 2012 | 09:56 AM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Horn Doesn't Work?
Gurus, what are common causes for the horn to suddenly stop working? Any common issues to look at, or easy fixes? Thanks in advance!
Car is 1991 Formula with air-bag steering wheel.
Old Feb 14, 2012 | 10:28 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Horn Doesn't Work?
1-check fuse
2-cancelling cam could be broken(most likely)
probably going to have to pull wheel to check that and the springs.
Old Feb 14, 2012 | 11:35 AM
danziger's Avatar
Originally Posted by mantaguy
1-check fuse
Thanks, bud! Fuse is good (shoulda mentioned that). I'll have to pull the wheel this weekend and see what develops...
Old Feb 15, 2012 | 08:10 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Did both sides quit working? You could first pull the airbag off to check the breakable plastic horn buttons and to see if the spring loaded end stays in the canceling cam tube Ok, or that the ground wire is intact. Have to do that to remove the wheel anyway, and the problem could just be in there
Old Feb 16, 2012 | 04:20 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
on my buick i had to wiggle the wires at both horns the other day because they wouldn't work to get the car inspected.corrosion where the horns plug in.
Old Feb 16, 2012 | 08:55 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Try the switches on the wheel first. They are easy to replace and frequently break afte 20 years. To test, pull the lead and short it. If the horn works, replace the switches.
Old Feb 22, 2012 | 09:17 PM
danziger's Avatar
Hmmm. Gonna try this first and then make my way to the plastic pieces and also look for corrossion as mentioned. Didn't get to it yet because of weather and travel....thanks for all the advice!
Old Mar 14, 2012 | 09:33 AM
FireballXL5's Avatar
Car: 1988 FORMULA
Transmission: 4spd auto
Axle/Gears: standard
my 88 formula horns dont work pulled the horn buttons the look brand new, looked for fuse didnt find one in the fuse block, cant find the horn relay, the hayne manual has nothing on horn no schamatic, nothing in index,
Old Mar 14, 2012 | 07:48 PM
mantaguy's Avatar
Engine: 5.0 EFI
Horn relay is in the convenience center,its on the right hand side on the wheel under the dash.The horn also has a 20 amp fuse,check the fuse box.
Old Mar 14, 2012 | 09:10 PM
Car: 1988 FORMULA
I replaced the relay, cant find the fuse for the hornin the fuse block, it isnt listed on the block, but all the fuses are good
Old Mar 14, 2012 | 09:11 PM
Car: 1988 FORMULA
I replace the relay, cant find the fuse in the fuse block all the fuses are good
Old Mar 14, 2012 | 09:32 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
The horn's fuse is the same one used for many accessories. If it was blown, then you would have no dome light, electric door locks, hatch release, cigarette lighter, under-hood light, and maybe a couple more. If any of them work, then it's safe to say the fuse is good.
Most likely, your problem lies in the wheel with the horn button. I'd also check at the horn itself in the fender, maybe a loose wire...
Old Mar 15, 2012 | 11:18 AM
Car: 1988 FORMULA
Thank you for that info found the fuse, it was the crtsy fuse, now here is another proble rear hatch wont close, the horn works but have to hit the button just rt, otherwise it goes blagh.
Old Mar 15, 2012 | 03:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
If you have to hit the button just right to make it work,It's the button or the plug to it is loose.
Old Mar 10, 2016 | 04:28 PM
BPaul91's Avatar
Car: 1991 Firebird Converible
Engine: 305 V*
Transmission: Rebuilt Automatic
I also have a horn (in a '91 FB Convertible) that will not work! Found fuse (ACC 20 amp) it's fine.. Founds both fans on DS fender.. I'll try cleaning contacts up… Likely it is the horn button.. What should it look like?? I see two contacts but nothing there to make the touch?? What should be in there?? I'll check the relay as a last resort!!
Old Mar 11, 2016 | 09:37 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Had to replace the buttons when I first bought my '91 GTA. Easy fix. You don't need to remove the whole steering wheel, just the airbag IIRC. Make sure you pull the airbag fuse before pulling the airbag. Make sure you pull the ACC fuse before replacing the switches.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
