Busted turn signal lever
Old Feb 24, 2012 | 12:56 AM
jaymzallyn's Avatar
Car: 89' Camaro RS
Engine: 2.8 MPFI
Transmission: borg warner 5 speed
Axle/Gears: stock
As if work wasn't a big enough PITA today, my signal lever decided to bust it's self clean off on my way to the store this evening. Not all bad though, I never really knew how they worked until now. I always assumed that like other cars I've had to pull the steering column off from that it was riddled with wires, but i was pleasantly surprised to find that ours (or alteast for my particular model) are strictly mechanical. Mine broke on the steel shank that runs all the way through the lever. It seems that the turn signal and high beam are controlled by the plastic grooves that interlock from the lever to the steering column, and the wipers/washer function is controlled by the steel rod. Since the busted part was steel I thought I'd give JB weld a go. Couldn't find it and ended up going with locktite's version. I held it in place for the recommended 15 minutes and I plan on letting it harden over night before I give it a go. I'm really not letting my hopes get up too high, I can envision it snapping the first time I use it on the way to work tomorrow. Wish me luck.
Old Feb 24, 2012 | 01:00 AM
lectric80's Avatar
Car: 83 Z28 T-top
Engine: 350 carb'd
Re: Busted turn signal lever
Go to most any auto parts store, grab a new one, and pull the old one. They simply pull straight out, no disassembly required unless you have cruise which you didn't mention. But man, how hard do you hit that thing?Good luck with the repair, but I would be surprised if it holds together for long.
Old Feb 24, 2012 | 09:26 PM
jaymzallyn's Avatar
Car: 89' Camaro RS
Engine: 2.8 MPFI
Axle/Gears: stock
Thanks for the luck! Didn't hold though. I actually bent it about 4 years ago, looking back I'm surprised it held up this long. I had a chain on my wallet at the time and it cought on the lever while I was getting in. We have all major parts carriers in this town and nobody had it in stock, not even the dealership I work at. I ended up fishing around and I've got one coming in at carquest tomorrow morning made by Doorman (only 12 bucks). And of course after I ordered it, I realized that since I'm going to have to drill into the piece that is still in the column I could have easily just repaired it by drilling a matching sized hole in the old lever and jb welding something the same size as the hole into them. I may do it just so i have two. I really appreciate your helpful response!
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
