Sticky Accelerator Pedal
Old Mar 7, 2012 | 06:26 PM
TimMcLeod's Avatar
Hi,
I've just bought an '88 GTA. The first thing I've noticed is that the accelerator pedal sticks for the last few mm when I lift. It eventually releases (after a few seconds) but it does mean that when I'm braking to stop the engine over revs.
My initial thought was that there must be a release spring that may need replacing but there doesn't seem to be one.
Has anyone else had this problem? If so... HOW THE HELL DO I FIX IT!?
Tim
Old Mar 7, 2012 | 07:51 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Sticky Accelerator Pedal
Declip the throttle cable at the TB and feel both for smoothness to determine if the pedal and cable are free.
Old Mar 19, 2014 | 04:38 PM
TimMcLeod's Avatar
Thanks but no need... turns out that part of the dash was pushing on the pedal arm. Simple!
Old Mar 19, 2014 | 05:29 PM
miamivice's Avatar
Car: 88 GTA
Glad you figured it out!
Old Mar 20, 2014 | 01:29 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
More embarrassing things have happened, one time I thought my gas pedal was sticking at a certain throttle position. I looked over the pedal, cable and linkage, turns out that the top of the pedal was just catching a ridge on my shoe.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ironbmt
Sep 27, 2015 06:00 AM
