LED Cluster done with LED strips
Old Mar 11, 2012 | 08:00 PM
cdoyle's Avatar
Hi,
Been wanting to add LEDs to my cluster but didn't want to use the plug n play LEDs, because they always have hotspots.
So instead what I did, was installed those LED strips inside the cluster.
This allowed me to place the LEDs where I needed them. I think overall it turned out pretty good.
I would like to get a couple more strips and try and make the needles light up better. I would love it if those were super bright.
Also for some reason my oil gauge is slightly brighter than the rest. It looks worse in the picture, but it is noticeable so I might have to move a strip around to even it out.
Here is a picture of the strips in place, I used an empty 194 socket to plug right into the factory plug.
Before LEDs:
After LEDs
Old Mar 11, 2012 | 08:03 PM
cdoyle's Avatar
Re: LED Cluster done with LED strips
What I do like the most is, I can actually read the odometer in the dark now. Before, you just couldn't see what the numbers were at.
Old Mar 11, 2012 | 08:51 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
( Speedo & tach needle? )
Good job!
Old Mar 11, 2012 | 11:02 PM
cdoyle's Avatar
Here is a better picture, I didn't realize that the first pic made the speedo and tach needles pretty much invisible.
You can see them, I just want all the needles even brighter.
Old Mar 11, 2012 | 11:45 PM
wsteiger85's Avatar
Car: 91 Z28
How do i get those LED strips i love that look and idea.
Old Mar 11, 2012 | 11:46 PM
BT85's Avatar
Car: 85 Camaro Z28
thats sick!
Old Mar 12, 2012 | 03:16 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Looks sweet man
Old Mar 12, 2012 | 08:57 AM
cdoyle's Avatar
I got them from superbrightleds, mine are the superwhite ones.
Old Mar 12, 2012 | 09:16 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Looks like a nice opition compared to a plug-n-play LED.
Old Mar 12, 2012 | 03:45 PM
cdoyle's Avatar
Thanks, I'm pretty happy with how it turned out. Looking forward to taking it out at night and see how things look.
Old Mar 13, 2012 | 07:10 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have the same 140mph cluster. I may have to try this myself, although I have no experience with LED's.
Old Mar 13, 2012 | 12:44 PM
SweetblueZ28's Avatar
Just curious you said there superwhite ones how come they look green?
Old Mar 13, 2012 | 01:44 PM
cdoyle's Avatar
hmm, I don't really think they look green. I guess there could be a green tinge to them. and that would be because 'superwhite' has a blue hint to it, you can see it where the odometer numbers are.
And since the 91/92 style gauges have yellow writing, the yellow and blue will create a slight green effect.
Old Mar 19, 2012 | 02:14 PM
reride's Avatar
Car: 1989 IROC-Z Convertible
Engine: 5.7 TPI
Axle/Gears: 3:23 Posi w/ alum. driveshaft
Nice job! Do they still dim? They look like they could be a little bright.
Old Mar 19, 2012 | 08:17 PM
cdoyle's Avatar
They do not dim with the stock dimmer, but I'm sure somethig could be done to make that work. I have LEDs in my 4Runner, and they dim with the stock dimmer switch.
Old Mar 19, 2012 | 08:18 PM
cdoyle's Avatar
oh, and they are not really that bright where it would hurt your eyes or anything. I'm actually thinking about putting a few more in there to brighten it up just a tad bit more.
Old Apr 9, 2012 | 07:15 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
What year Cluster is that?
Old Apr 9, 2012 | 09:38 PM
cdoyle's Avatar
It's a 91/92 cluster out of a Z28.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
