Floorwell light fuse
Old Mar 12, 2012 | 07:10 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I recently bought new LED's to put into the lights located under the dash that lights up the floorwell but it doesn't turn on. The dome light and auto shifter light works perfectly . Are these lights on a seperate fuse? and if so, which one? thanks
Old Mar 12, 2012 | 09:18 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Floorwell light fuse
They are on the same fuse,the book says if several circuits don't work check the ground on the fuse box.Did the lights work before you changed to led.
Old Mar 13, 2012 | 03:06 PM
Axle/Gears: 3.45
No, the lights still didn't come on before I put LED's in there. How do I check the ground wire on the fuse box?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
90formulaVortec
Sep 3, 2015 09:26 AM
