hatch motor constantly running
Old Mar 13, 2012 | 07:55 PM
Scootermunch's Avatar
Car: 1989 Trans am GTA
it doesnt want to stop from being 'on', i think it is currently in the 'down' position, so it keeps wanting to pull it down more. if that makes sense. i replaced the relay as a longshot guess, to no avail. am i needing a new motor, or is it something else i need to check?
Old Mar 13, 2012 | 08:24 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: hatch motor constantly running
Top down solutions has a really good PDF on the hatch pull downs: http://www.top-downsolutions.com/Doc...structions.pdf
Make sure to check out step five in the very last set of instructions too.
Old Mar 13, 2012 | 08:29 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
I have the same problem thanks this should help
Old Mar 22, 2012 | 09:42 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Use the Tech Article that I posted on TGO under the General Repairs category instead of the instructions from my web site. We're completely re-doing the TDS web site to run on new software, so unfortunately all those old links most likely will no longer work.
Remember, hatch motor running continuously = bad gear nut.
If anyone needs to order parts or has a tech queston for me, call or e-mail me. The site should be up again soon, but it may be a couple of days working thru all the little glitches. FYI, I'm not migrating any customer info over to the new web site, so you'll have to register again. I still have everyones customer info (addy, etc saved on QuickBooks though).
Lon Salgren
626-369-0040
topdownsolutions@yahoo.com
Vintageracer
Jan 10, 2020 05:33 PM
Randomtask2
Aug 13, 2015 01:57 AM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
