Roll bar/cage
Old Mar 16, 2012 | 12:57 PM
1fastrock's Avatar
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
Roll bar/cage
Hey guys I've been trying to search for what kind of cages/roll bars people are running in their street cars but have come up short. Any suggestions would be helpful and pics would be even better. I'm putting it in an 89 camaro with aftermarket seats. More of a track car now but it does see some road time every now and again.
Thanks in advance
1fastrock
Old Mar 16, 2012 | 01:13 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Roll bar/cage
Roll bars. Scream Race Car.
you will get alot of replys. from guys running what they think is the best set up.
down load. or get a Copy of the rule book (what ever body your racing in)
Drag Racing NHRA Rules can be looked up on the net. and what you need for what speed you will be running. sorta stuff..Good read.
and start shopping (you can always upgrade)
AutoPower Makes a good bolt in bar to start with. (you can add to it has you go) adding side bars to the main hoop and going from there.
S&W Race cars makes a Fantastic set of side bars.
just remember. with the 3rdgen camaros. you dont have to weld them in.
so you can go with the bolt is has well.
and swing out side bars are NHRA/IHRA ..OK
you will see stuff like
with back seat..
without back seat
and info telling you whats safe and what they think is not safe.
remember guys have been installing roll bars in cars for the last 50 years.and no 2 are alike!
Some look Good!..Some not so Much. its a big market.
STAY WITH the same size tubing (if upgrading)
Good Luck and Have Fun!
Old Mar 16, 2012 | 08:16 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
Re: Roll bar/cage
Where can I find some pics of the swing out side bars?
Old Mar 17, 2012 | 03:01 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: Roll bar/cage
I always wanted a Wolfe Roll Bar in my 2002 Camaro. Would be fantastic if they made the 6 points for 3rd gen.
Old Mar 18, 2012 | 08:02 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Re: Roll bar/cage
Here are a few old pics of my rollbar with swingouts
Attached Thumbnails Roll bar/cage-swingout1.jpg   Roll bar/cage-swingout2.jpg
Old Mar 18, 2012 | 08:03 PM
ryn28's Avatar
Engine: Chevy ZZ4
Re: Roll bar/cage
Two More
Attached Thumbnails Roll bar/cage-swingout3.jpg   Roll bar/cage-swingout4.jpg
Old Mar 18, 2012 | 08:53 PM
skinny z's Avatar
Re: Roll bar/cage
Here are a couple of examples. From a full cage to a 6 point with swing outs.
https://www.thirdgen.org/forums/thir...-business.html
Old Mar 19, 2012 | 12:47 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Roll bar/cage
Some nice work here. Im looking to do a cage over the coming winter. Yeah I know its a long way off but it helps to plan ahead
Old Mar 19, 2012 | 01:06 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Re: Roll bar/cage
Don't have better pictures off hand but this is what I did (BTW, those holes are patched up now, pics taken a year ago...). Bars are completely custom. Instead of a swing out bar we "bent" the bar so it clears the arm rests. We then reinforced the bend with a diagonal to the base of the main hoop (you can see it on the far side of one of the pics). Easy to get in and out of the car (front seats of course). We also moved the main hoop back to hide it a little, this is to reduce the racer look on the street (with interior the bar tucks up really tight and is hard to see in a casual traffic check).
We observed much better chassis rigidness with the roll bar--which was the point for me (we did the bar before the frame connectors as part of the experiment). It was even better with the frame connectors (which tie into the roll bar).
I am sure it will not pass NHRA (we did use the correct tubing throughout but did not follow the book otherwise) but I have no need for that either, just taking the flop out (T-Top car). Not that there is anything wrong with building to the rule book of course, it is just about what you want/need to achieve.
Sorry again for the ugly pics...
Attached Thumbnails Roll bar/cage-028.jpg   Roll bar/cage-023.jpg
Old Mar 19, 2012 | 08:49 PM
skinny z's Avatar
Re: Roll bar/cage
I agree however it seems like the planning never stops!
Old Mar 20, 2012 | 01:30 PM
6SIX6's Avatar
Car: 89 IROC
Re: Roll bar/cage
No kidding all I wanted was to drive the car after i fixed the old 305 well 5 years later and 3 cars later I got a fully built LQ4 , T56 , Hybrid 8.8 and god knows what else Ive done and now onto a roll cage just so I can go down the track. LOL it never ENDS!!!!!!!!!
Old Mar 21, 2012 | 09:12 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Roll bar/cage
Originally Posted by ryn28
Two More
I like that. Is it a custom made setup or is it an off the shelf kit (and from whom)?
Old Mar 21, 2012 | 05:37 PM
ryn28's Avatar
Engine: Chevy ZZ4
Re: Roll bar/cage
Thanks.
It was not a kit but built from scratch and installed by a local chassis shop in W. Babylon LI, MI Performance - http://miperformance.com/
I went that route because I don't know how to weld (not now at least) and I wanted the best fit possible.
Old Mar 22, 2012 | 01:33 PM
Jim85IROC's Avatar
Re: Roll bar/cage
Thanks.
Have any pics from the hatch area?
Old Mar 22, 2012 | 05:06 PM
ryn28's Avatar
Engine: Chevy ZZ4
Re: Roll bar/cage
Here's what I have
Attached Thumbnails Roll bar/cage-dscn0094.jpg   Roll bar/cage-dscn0095.jpg
Old Mar 22, 2012 | 05:07 PM
ryn28's Avatar
Engine: Chevy ZZ4
Re: Roll bar/cage
and these
Attached Thumbnails Roll bar/cage-dscn0103.jpg   Roll bar/cage-dscn0104.jpg
Old Mar 22, 2012 | 08:36 PM
Re: Roll bar/cage
this is a bolt in AutoPower NHRA/IHRA ok
before the swingout side bars
(swing out to make it easy getting in and out)
note: back seat will not fold up (dont need it)
and you still have lots of room in back.
Old Mar 22, 2012 | 08:58 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Roll bar/cage
This street car enuff 4 ya??
Still can put the TTOPs in back
Old Mar 22, 2012 | 09:28 PM
DD9TransAmGTA's Avatar
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
Re: Roll bar/cage
I'm thinking of putting a cage like that in mine and take out the back seat! jeez your brave enough to drive to wally word in your firebird? My friends brothers cobra got door checked around there!
Old Mar 22, 2012 | 09:33 PM
TTOP350's Avatar
Re: Roll bar/cage
I still have the back seats in my car. they dont weigh enuff to take out plus the weight is close to the rear wheels..
The Ultima "GTA" front seats weigh 100lbs together 60# for the dr 40# for the pass. Now those should be removed !
Old Mar 22, 2012 | 09:41 PM
Re: Roll bar/cage
I need a set of those ultima seats! really looking for a red set. Back seat will be pretty much useless for me.
Old Mar 22, 2012 | 10:26 PM
TTOP350's Avatar
Re: Roll bar/cage
I had a beatup interior that I sold not long ago, red ultima cloth seats. cloth was tornup and foam was hurtn.. 100 for it all
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
shanelique22
Oct 3, 2015 07:23 PM
FormulaEngland
Sep 30, 2015 01:50 PM
