fiberglass dash??? JUST ADDED PICS
Old Mar 29, 2012 | 05:18 PM
ROCmy86's Avatar
Car: 86 IROC
Engine: 355 Stealth Ram
has anyone done a fiber glass dash and if so how? i want to take my cracked dash pad out and fiber glass it and paint it and maybe do some custom tweek or two. Any info would be awesome!
Old Apr 3, 2012 | 08:57 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: fiberglass dash???
It would be super easy to do in terms of fiberglassing goes.
1. Remove Dash Pad
2. Fill the cracks with spot putty. Once it dries, sand it smooth.
3. Sand over the dash pad with some 80 grit.
4. Wrap the dash pad with a stretchy fleece. Use a staplegun to affix the fleece to the bottom of the dash pad. Note that you will have a bit of an overhang so you will want to go further toward the middle to make sure you cover all that can be seen with fleece. Make sure there are no creases / folds.
5. Test fit the dash pad and make any necessary mods.
6. Mix up some resin.
*pro tip - pour several smaller batches of resin in mixing cups. Pre measure your hardener. This allows you to quickly mix a new batch so it doesn't all harden on your. MUCH less wasteful.
7. Brush resin onto the fleece until completely soaked and let dry for a few hours or overnight.
8. Sand the dash pad with some 80 grit until completely scuffed up.
* pro tip - WEAR A RESPIRATOR. Breathing this stuff is worse than chain smoking a carton of newports.
9. Apply a thin layer of body filler over the dash pad and let set.
*pro tip - you can thin out your body filler with fiberglass resin (make sure to add your fiberglass hardener). This will allow you to paint on a thin layer using a brush. Makes for a lot less sanding. If you are going to do this, practice until you get the right mix for your desired result.
10. SAND SAND SAND SAND SAND SAND SAND GUIDECOAT SAND SAND SAND
11. 2k Highbuild Primer
12. Sand down to about 500 grit
13. Clean with wax / grease remover
14. Paint
15. Enjoy the envious stares of your friends.
Old Apr 3, 2012 | 02:55 PM
ROCmy86's Avatar
Car: 86 IROC
rukus awesome post thanks u confirmed what i already thought needed to be done. i knew watching all those overhaulin episodes would pay off ill prolly do the dash little by little over the next month and ill post pics as i go along.
Old Apr 3, 2012 | 02:57 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
I'll probably be doing something similar over the winter in the iroc along with some door panels and a center console. 4x6 speakers make no sense so i'm just going to glass over them and put some components in the door panel.
Be sure to share your results and progress!
Old Apr 3, 2012 | 03:08 PM
ROCmy86's Avatar
Car: 86 IROC
def will im wondering if you can change the 4x6s and mount a component system like a 4 inch or 6 inch woofer there cause for some reason i really love the clean door panels. im gunna look into that in the coming weeks and see what can be done.
Old Apr 3, 2012 | 03:12 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Might look kind of gaudy. My recommendation would be to do it right, glass over the dash and install some of these bad boys.
http://www.qlogicdirect.com/index.ph...products_id=61
Old Apr 3, 2012 | 03:15 PM
ROCmy86's Avatar
Car: 86 IROC
that might look good i have nothing set in stone yet im honestly in the planning/ design phase i just bought the car 2 weeks ago. its my toy so im playing little by little getting it running right and looking right before i register her and show her off
Old Apr 30, 2012 | 09:50 AM
ROCmy86's Avatar
Car: 86 IROC
so far dash is coming alone pretty well i pretty much have all the bondo and spot putty work done just sanding and shaping. will post pics when its done should be complete in a week or so.
Old Apr 30, 2012 | 09:59 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Awesome! It's a lot more work than it seems, but it should come out sweet!
Last week I repainted the front air dam of my IROC. I used the dupli-color bright red base and discovered the BEST SPRAY CAN CLEAR that i have ever used.
http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
I highly recommend picking this up when you paint your dash. It is only good for 48 hours once you activate the can but it lays out thick and smooth.
Old Apr 30, 2012 | 10:34 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I'd love to see pics when your done
Old Jun 7, 2012 | 09:43 PM
ROCmy86's Avatar
Car: 86 IROC
Here is what ive got done. Its not perfect its the first time ive ever done a dash and i figured id try to be alittle more creative then just paying for a new one.
-I filled the cracks in the dash
-coverd with fleece
-fiberglassed the dashpad
-sanded and sanded
-bondo the pad
-sanded times 1000
-wrapped in a black vinyl (i messed up on the corners and i didnt wanna tear it all off and do it again so i found some carbon fiber vinyl)
-Carbon fiber vinyl on the edges
-laid my gold stripes
had an idea about the center (to much open space)
-Cut IROC-Z in carbon fiber and trimmed edges in gold
Lemme know what you guys think of it!!
Attached Thumbnails fiberglass dash??? JUST ADDED PICS-hpim0455.jpg   fiberglass dash??? JUST ADDED PICS-hpim0456.jpg   fiberglass dash??? JUST ADDED PICS-hpim0457.jpg
Old Jun 7, 2012 | 10:36 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
-coverd with fleece
-sanded and sanded
-bondo the pad
-sanded times 1000
I think it might have been easier and possibly better to remove all of the vinyl from the dash pad leaving only the foam, then put glass on top of that, sand, bondo, sand, prime/paint/clear. Thats the way I have seen it done many times.
Old Jun 8, 2012 | 07:08 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: fiberglass dash??? JUST ADDED PICS
Very creative! Beats a cracked up dash anyday.
Old Jun 8, 2012 | 09:18 AM
ROCmy86's Avatar
Car: 86 IROC
thanks rukus i thought it turned out pretty cool, i havent seen anyone on here do a custom dashpad yet.
Old Jun 8, 2012 | 11:31 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I've seen a few. Last year I read up on a thread where the guy used rhino liner. Looked pretty good because of the rough texture the end results had. I also saw one that the guy had painted red skulls on his customized dash pad.
Old Jun 8, 2012 | 11:32 PM
https://www.thirdgen.org/forums/inte...seen-done.html
Jorlain
Aug 24, 2022 05:11 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
sweet_87_iroc
Mar 27, 2016 04:05 PM
toones
Jan 6, 2016 06:00 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
