91-92 HMSL problem, need help
Old Apr 6, 2012 | 10:17 AM
Badrs2810's Avatar
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
I posted this in the electronics and haven't gotten any help, so maybe I will here: just found out my high mount stop light in my 91 camaro doesn't work, it's not even wired up. Idk where the light goes to or anything. Can someone assist me in wiring this to the brakes so when the the brakes are pressed the light works? Would running new wires to the brake light wires, splicing them into the brake lines, and soldering or taping it off work? How were they wired originally (ground/power)? Any help would be awesome, thanks guys!!
Old Apr 6, 2012 | 12:32 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: 91-92 HMSL problem, need help
Your tail light harness is loomed and goes over the driver side rear wheel well, trace back the ground and power wires for the brake lights and just splice it into that. It would require pulling the carpet up and removing the rear plastic panel in front of the tail lights but definitely easier than running the wire up to the fuse box.
Old Apr 6, 2012 | 12:51 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
I will definately try that.... It's a little cold out right now, odd, but I figured splicing in is a lot simpler than trying to run and hide the wires as well
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
