sick of static shocks
Old Apr 9, 2012 | 03:32 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Anyone every have a problem with static shocks when getting out of your 3rd gen???
Getting on my nervers big time, I can't even sit down for a split sec and when I get out I get a nasty shock when I touch the door.
Yes all cars seem to do it sometimes, but its every single time, almost like I need to add a ground strap from the seat fabric to the body
factory seats, no covers.
Old Apr 9, 2012 | 04:02 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: F'in sick of static shocks
SNAPZAP.....
What the,,??...
Usually after driving a lil bit & touch the door to get out.
Sometimes just a pop, sometimes an all-out arc!!.....
Old Apr 9, 2012 | 04:18 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I could weld with the shocks Im getting after just a sec in the seat
Old Apr 9, 2012 | 05:47 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
My car must be well grounded because I don't have this issue lol.
Old Apr 9, 2012 | 08:51 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I'm getting it to,I think it's seasonal,it only happens this time of year!!!
Old Apr 9, 2012 | 09:19 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
It is the cold weather. I can't think of one thing I've ever gotten shocked by my car here in Texas, even in our "Winters".
Old Apr 9, 2012 | 09:58 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The higher the humidity, the less chance of static shock.
I usually get a nice spark after exiting the car and touching the door. I keep my hand on a metal part of the door/body as I step out an onto the pavement. No sparks.
Old Apr 9, 2012 | 10:01 PM
Car: GTA
Nice theory (humidity) but it was DRY all Summer here plus little rain the rest of the year. No static even in the dry times here. But I bet leather is worse about static than the cloth seats. who here has leather & static problems? Cloth for me.
Old Apr 9, 2012 | 10:13 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Iv never had this issue
Old Apr 9, 2012 | 11:06 PM
Dakota W.'s Avatar
I'm a clothie as well.
Old Apr 9, 2012 | 11:31 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
This is true. It's why my workplace has humidifiers. IIRC, we keep the humidity above 30% to reduce the chance of electrostatic discharge while working on printed circuit boards.
Old Apr 9, 2012 | 11:44 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
Old Apr 10, 2012 | 12:08 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Never seen pleather seats standard but in a 2nd gen, thought all 3rd were cloth???
Old Apr 10, 2012 | 01:27 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Ive got that same issue ever since I replaced my interior and it was getting damn annoying so I went and got me one of those anti-static spray dealies seems to be working pretty good. I got it from walmart in the laundry section for a couple bucks.
Old Apr 12, 2012 | 05:19 PM
Dezined's Avatar
Car: 91 Camaro RS - B4C option
Engine: L98 5.7l V8
Transmission: 4 speed auto
I feel your pain. However, I get shocked no matter where I go or what I touch. Everytime I get outta the car, my Camaro or the wife's Magnum, I get shocked so bad it makes my fingers hurt for a while. Then I touch the door of whatever building I'm going in, and get another one. In my car though, I used to get out with my hand on the side of the seat. I'd get shocked from every little pore in the seat it felt like, and that **** hurt. Got used to grabbing actual metal on the car, and it still hurts, but it's just one shock, instead of a buncha little ones like w/ the seat.
Old Apr 12, 2012 | 07:03 PM
mantaguy's Avatar
Engine: 5.0 EFI
You can do what they did in the old days!!!hang two straps from the bottom of the car that drag the street.That worked well when you paid the toll taker,neither would get shocked.You young guys would't know what I'm talking about
Old Apr 12, 2012 | 07:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I found if I touch my leg to the door sill as I get out and before I touch anything, it will set it off and the insulation from the jeans and the numbness in my lower right calf, its a slight poke instead
Old Apr 13, 2012 | 09:02 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
lol I used to have a pair of shoes that did this. If i walked on any kind of carpet I could burn paper with my finger from the zap lol.
Old Apr 13, 2012 | 10:49 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Just hang onto the door/sail panel, any metal piece as you step out. Any charge will dissipate through your feet to the ground, without a shock.
Old Apr 17, 2012 | 10:05 PM
1lstpass's Avatar
Re: sick of static shocks
I have had the same problem this past month! I sprayed my seats, carpet and door panels with a product called Static Guard that I got at a common retail store and it completely took care of the issue.
Old Apr 18, 2012 | 12:52 AM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Believe it or not wind can cause static. So does friction. ( balloon rubbed on cloth then held close to hair makes hair stand up. ) Some gas stations tell you NOT to get in your car while filling it. When you exit the car the spark from cloth on cloth friction can start an inferno.
Open door, step both feet on the ground, hold onto the window, stand up, then lock the door and close it.
That's the Only thing I can think of. If all else fails, blame someone else lol
Old Jun 6, 2014 | 12:02 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thought about this and my newish seat covers, giving my double strength static shocks.
I shoved several dryer sheets in between the two, static gone.
Old Jun 6, 2014 | 02:19 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
I usually put my feet out, hold my hand against the body, door frame or some other metal part, get up, close the door and so prevent myself getting shocked.
Old Jun 6, 2014 | 07:27 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
A "Shocking Revelation" Gumby! I been getting shocked for 26 years. I'll try that.
Old Jun 6, 2014 | 10:46 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
it was bad enough with just stock seats, but seat covers are a nice velvet like material and it was like a cattle prode then...........
Old Jun 6, 2014 | 11:19 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
My Grandfather had them on his 68 Chrysler Town&Country Station Wagon. That car had a 440 in it and went so fast when he drove, he needed em. No ZAP!
Old Jun 6, 2014 | 03:43 PM
Joe Tag's Avatar
All winter I get blasted every time I get out of any car. Humidity plays a huge part in this, but the type of clothing you wear does too. Nothing but cotton in the warm months and no shocks, humid or not. Synthetics build a good charge up. Hoodies are a blend of polyester and cotton. ZAP!
Old Jun 6, 2014 | 05:02 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Those things looked or look goofy. I member them and curb feelers on cars.
always has a stand out lighten bolt on them, new ones on ebay are reflector city.
maybe if painted black and hung like off the axle so its no easy to see them...
Or just bend down one of the coat hangers holding up the exhaut to drag on the ground
Old Jun 6, 2014 | 05:52 PM
racerx520's Avatar
my solution to the static shock was just to hold my left hand against the body while sliding out. therefore i ground myself. the way i see it, is that youre using yourself as a capacitor when sliding out and getting the static electricity buildup in your body. when you ground yourself when getting out, you solve the problem of storing the tiny bit of electricity in your body
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Linson
Oct 1, 2015 09:50 PM
meeklay812
Oct 1, 2015 03:46 PM
