T5/T56 shift pattern fix
Old Apr 27, 2012 | 09:58 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
When I got my car there was no shift pattern just an open hole in the shifter plate. Also missing was the white box the bulb mounts to. I bought the T56 shift plate from Hawks and decided to make a box to mount the bulb to light it up.
Plate from Hawks
It fits in pretty snug to the shift plate
I had some ABS plastic from wheel pants for an RC plane kit I have
I used CA (krazy) glue to glue it together
I put this piece in to make sure the pattern doesn't fall down in.
I made it just a bit too tall do the shift boot bracket hold it in. If it doesn't work out I'll make up some mounts for it. Don't mind the fiberglass cloth. It is what I used along with CA glue to fix my cracks.
orange cover on bulb
All lit up
The original box is painted red inside with no bulb cover. I may end up doing this as the bulb cover makes it too orange. But I just happened to have the cover so I used it.
Old Apr 27, 2012 | 10:12 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: T5/T56 shift pattern fix
very cool!
Old Jul 31, 2013 | 03:58 PM
Jaysz28@work's Avatar
I bought one, but can't figure out how to remove the 5 spd pattern, or the light box.
FWIW, I didn't realize I had a light box, so I get to research that as well.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F-body driver
Mar 6, 2023 11:44 AM
Jorlain
Oct 8, 2015 01:57 AM
TheTraut88
Sep 11, 2015 05:16 AM
89fast5oh
Sep 8, 2015 09:55 AM
