Broken Speedometer Needle
Old Apr 30, 2012 | 03:51 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
So i "upgraded" the dash lights with LED lights and in the process i broke the speedometer needle. The needle itself is not broken but the little point where it goes inserted broke. Any suggestions?
Old May 1, 2012 | 12:10 AM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
Re: Broken Speedometer Needle
tiny bit of super glue?? just use a pic of another speedo for reference so you dont have to try to break it off again
Old May 1, 2012 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the 'pin' that the needle sits on is bent/broken, you'd probably be best advised to replace the speedo head.
JamesC
Old May 2, 2012 | 04:05 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
So does this mean i need to take a trip to the junkyard, or can i use a speedo head off of a 85 mph speedometer?
Old May 2, 2012 | 06:29 PM
JamesC's Avatar
You can swap in an 85, a 110, or a 145 speedo head (82-89 mechanical). I'd swap in the head rather than the entire cluster to avoid possible electrical gremlins.
JamesC
Old May 7, 2012 | 03:59 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
James,
Whats the proper way of removing the needle on these cars? Mine came right off but when i put it back it broke off. I went to the junkyard and found 1 camaro with the 110 speedometer, tried to remove and it too broke off. Now i got one coming from e-bay and i dont want to make the same mistake. Any suggestions?
Old May 7, 2012 | 04:21 PM
JamesC's Avatar
As you can imagine, after several years in the elements, the plastic is incredibly fragile. I wouldn't attempt it myself, but I've read where members have experienced good results by using a table fork (slide the 'pin' through the tines of the fork and gently pry upward (close your eyes, pray, and hold your breath).
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
no green
Jan 9, 2016 09:22 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
