LED gauge confusion from many threads
Old May 8, 2012 | 12:17 AM
TVIROCZ's Avatar
Car: 1987 Chevy Camaro Iroc Z
Transmission: Automatic (700R4)
I want to put LED bulbs into my gauges and I am doing some research. The threads on LEDs for the gauges are confusing and I can't find an answer. What I want to know is for my 87 Camaro
1. Do I use a 194 or 161?
2. How many bulbs do I need? ( excluding the engine check light and seatbelts)
3. What the brightest you would recommend? I am planning on putting blue lights in
Old May 8, 2012 | 03:55 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: LED gauge confusion from many threads
I used 194's in my '85 I believe their are 11 in the cluster and one for the HVAC
Old May 8, 2012 | 06:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Number for the cluster:
http://www.macewenmotorsports.com/howmabudoine.html
The following tip will help brighten the gauges:
https://www.thirdgen.org/forums/body...r-cluster.html
While you have the cluster removed, you might wish to repair the trip odometer (I assumed it's broken as most are):
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old May 11, 2012 | 10:53 AM
TVIROCZ's Avatar
Thanks, I am going to give it a shot this weekend. I got a 10 bulb pack but I have an LED in my map light which I will take out from there. The map light button is starting to stick and its not like I use it all the time anyway. Another this is I am debating on a white or blue. I got blue covers for the leds in my console and its not bright but it looks nice.
RazorN8
Jan 7, 2022 11:44 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 19, 2015 01:36 PM
fonzie85
Aug 13, 2015 11:50 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
