Interior plastic repair question...
Old May 23, 2012 | 08:47 PM
coconut88888's Avatar
Has anyone tried to repair the interior plastic pieces? Some of the fastener holes for the hatch surround area trim pieces are cracked and I'd like to keep mine as original as possible since I've had it since new. It's a 89 RS 305 TBI with T5 trans, black exterior and Carmine red interior. I parked in a few years back because of a rust hole in the roof skin that I need to repair. I drove it 363,000 miles up till that point.
John S>
Old May 25, 2012 | 11:47 AM
Re: Interior plastic repair question...
Come on - I know mine can't be the only ones to crack and need repair....
Old Jun 4, 2012 | 03:40 PM
HEAVY-T's Avatar
Car: 91 RS
Engine: 350 tbi
Transmission: W/C T5
Axle/Gears: 3:73
Im havin the same iquestion. Stripped out my interior the weekend and the previous owner over torqued all the console fastners, prob due to the T5 being repaired so often, so when I backed them off the corners came with them. Im planning on reinforcing the bottom and just glue and sand it all back. The side panels up the pillars are all broken too, Goin at it the weekend, Ill post some pics
Old Jun 4, 2012 | 04:48 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
https://www.thirdgen.org/forums/inte...ic-carpet.html
https://www.thirdgen.org/forums/inte...-plastics.html
Old Jun 4, 2012 | 06:38 PM
82tarecaro's Avatar
I had great results with the Plastifix. It will work to repair the tabs on the console pieces. They are made from ABS. It will NOT work on the interior plastics in the rear and cargo areas that are made from Polyproylene. Check the back of the panel to see what it is made from first.
Old Jun 4, 2012 | 07:32 PM
mantaguy's Avatar
Engine: 5.0 EFI
I knew you had did some interior plastic repair,so I gave him/her your thread on the subject.
Car done yet????
Old Jun 4, 2012 | 07:36 PM
Coyote850's Avatar
Car: '83 Z-28
Engine: 5.0 CFI
Transmission: 700-R4
Dude I totally respect wanting to keep it original. I've had my Z-28 for over 21 years and its almost completely original except the paint. But if a plastic piece breaks/cracks, its getting replaced. The plastic pieces don't have feelings, they won't be hurt. And nobody has to know but you.
Theres tons of plastic trim pieces on eBay or in the TGO for sale section.
Old Jun 4, 2012 | 07:38 PM
82tarecaro's Avatar
No problem Mantaguy - I hope it helps him out. Car is still not done. I am losing patience with the painter.
Old Jun 4, 2012 | 07:46 PM
mantaguy's Avatar
Engine: 5.0 EFI
Me too!!!I didn't want this to be a project car for them,but it seems to be turning into one.
I know how you feel.
Old Jun 4, 2012 | 07:50 PM
82tarecaro's Avatar
Try finding them unbroken. That is the problem. You can't go into your local GM dealer and buy a shifter plate for a 1982 Trans Am. And the junk that is for sale is worse then what was in my car. I did the next best thing. I fixed them.
Old Jun 4, 2012 | 09:42 PM
Coyote850's Avatar
Car: '83 Z-28
Engine: 5.0 CFI
I guess I've been lucky so far finding good parts. But yea, if you can't find a part then learning how to fix what you got is better than nothing.
Old Jun 5, 2012 | 10:01 PM
I appreciate the responses and the links. The interior is Carmine red which is difficult to find like everyone said in the other link. I'm the original owner of the car so it has some sentimental value that I find this info very helpful. Has anyone had luck repairing poly plastics?
coconut
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
BHR
Sep 3, 2015 07:51 PM
g.l.mos
Aug 22, 2015 12:02 AM
