86 FB dash change
Old May 25, 2012 | 06:04 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
86 FB dash change
Got an 86 base firebird with v6.Insterment panel is full of light warnings insted of gauges.will a TA or formula cluster go into my dash?also will I have to change the harness or just conectors
Old May 27, 2012 | 10:23 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 86 FB dash change
You may need to swap in the yellow speed sensor decoder box (to the back of the ECM bracket) as per the tech article and go from there. You current speedo is cable driven. I'll look up the wiring connectors in a bit, but I think mostly what you would need to do is to swap over the clusters, install the VSS box and parts, swap over the odometer into the electric speedo, and put in all new gauge senders in place of the idiot light switches (switches are on and off and won't work the gauges at all except the fuel and volts gauges). You will also need to get a V6 tachometer unless you like having the tach read wrong...
Old Jun 4, 2012 | 10:39 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I've got most everything out of my sons 90 dead bird.but this is a 86.what are the chances of a ta cluster working?From same year.think they had 120mph cluster
Old Jun 5, 2012 | 05:00 AM
Engine: 2.7L V6
Axle/Gears: 4.41
The same deal as above. The 90 used the sensor buffer integral to the ECM and an electronic speedo head. The cluster in the 86 may or may not have the electronic speedo head. If it doesn't, you will need to swap the speed sensor into the tail of the trans from the 90 in place of the speedo cable adapter but using the gear that was on the speedo shaft (to keep the speedo reading right). Then you can wire up the cluster using the proper wires from the ECM. I think you would want to connect into the brown wire coming off of the back of the speedo head (that runs to the ECM), but don't hold me to it.
If the 86 is already electronic, you would need to retain the buffer box at the back of the factory ECM bracket and wire the VSS wires to the ECM to the buffer VSS wires backwards (yellow to purple and purple to yellow). You won't need to replace the $40 VSS if you do this.
Jorlain
Aug 24, 2022 05:11 PM
toones
Jan 6, 2016 06:00 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
z28_AJ
Aug 27, 2015 08:59 PM
355tpipickup
Aug 19, 2015 10:02 PM
