Dome Light Fasteners?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Dome Light Fasteners?
http://www.clipsandfasteners.com/default.asp
Scroll down to retainers and you should find what your looking for.
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
I went down to Autozone and picked up the HELP Push Nut Assortment for 2.99. The circled ones are what you need.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Junkyard items. And that if got something else you needed, they probably wouldn't even charge you for them.
Engine: 5.0 EFI
them things are called starlocks
Car: '89 Trans Am
Transmission: 700 R4
I picked up a set just like that from Autozone, except mine were made by Dorman and cost like $1.50 more. I wouldn't have needed it if I didn't drop one of those washers into the abyss.
But the size antares circled is the size you need. I had to use a needle nose pliers to push the washers into position.
Car: '89 Trans Am
Engine: 5.0 EFI
Yes, some vice grips on them and they come out easily.
