Help w/ turn signal lever issue
Old Jun 4, 2012 | 10:07 PM
rebeldiamond777's Avatar
Car: 89 Iroc-z
Need help identifying a part
I recently purchased a 89 Iroc & part of the plastic steering column housing was previously damaged by someone attempting to steal it. In the process they ripped the turn signal off. The wiring is still in tact, so the lever works (wind shield wipers, signals come on if jammed a certain way), just needs to be reattached. I brought it to a shop & they said I needed an ENTIRE new steering column just to fix the dangling lever. So I took a closer look myself and I noticed that it looks like I really just need to replace the plastic piece behind the turn signal switch.
The lever
The piece the lever was ripped off of, circled in red
I did some research and I BELIEVE that this is the part I need:
http://www.rockauto.com/catalog/moreinfo.php?pk=1193579
Just want to know this is the right piece before I go out & get it!
Old Jun 5, 2012 | 10:21 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Help w/ turn signal lever issue
That would be the piece, but I know you can get it cheaper on eBay. You will also need the proper torx bits to get the shroud off and to remove the turn signal switch and wiper switch completely.
Old Jun 7, 2012 | 05:23 PM
Car: 89 Iroc-z
Sweet, thanks for the heads up!
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
