Can I use this..?
Old Jun 9, 2012 | 02:47 PM
orangek's Avatar
Can I use this..?
In my 91 Z28 my high beams are not activating. I thought it was the dimmer switch but it's not. The steering column was taken a part and when I got inside of it I noticed that a piece from the turn signal switch was broken which is probably why the high beams wont turn on. So I found the part I need but its for 1984-1989 Camaro's. I was wondering if it would work in my 1991 Z28? He's the part.
http://www.classicindustries.com/cam...ts/sw2174.html
Old Jun 20, 2012 | 03:26 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Re: Can I use this..?
I had a similar problem with my old 89 firebird. I went to autozone and asked for the high beam switch for an '81 camaro, brought it home, mounted it to floor (I think 3 self tapping screws) and the stock harness actually plugged right into the old style switch. Stock connector is right under dash, no disassembly required.
Then if it doesn't work for you, you can return it and get your money back. Easy to test, hardest part of the install is cutting a little hole in the edge of the carpet. Plus, I prefer the foot operated style.
Old Jun 20, 2012 | 05:32 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
On my 91 the rod running from the turn signal arm down to the switch is bent somewhere at the top. I had to lengthen the rod 1/8 inch for it to work properly.
Seems to be a somewhat common problem for these cars to have hi - low beam issues.
STIFFLER
Jan 1, 2003 06:18 PM
Skatepunk60
Dec 25, 2002 01:28 AM
definitive1
Aftermarket Product Review
Dec 20, 2002 10:34 PM
Hrock
Dec 17, 2002 11:49 PM
92fire-audio
Sep 5, 2001 12:10 AM
