Steering column/ turn signal stick help!
Old Jun 16, 2012 | 09:21 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Recently I had my steering wheel off and I bumped the stick with my head because I was crawling underneath the dash. Well, now the left flasher stays solid on the dash and the tail light, the front light doesn't even come on. Also I took the steering wheel off because it started clakkclakkclakking when I turned the wheel and shooting spark too, so my main question is how do I get the gear that locks the wheel out?
Old Jun 17, 2012 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Steering column/ turn signal stick help!
Maybe something helpful in the sticky below:
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
Old Jun 17, 2012 | 02:14 PM
Dakota W.'s Avatar
That helps quite a bit, thanks James!
Old Jun 21, 2012 | 10:34 PM
Dakota W.'s Avatar
Well, the metal piece that goes in between the 2 contacts for the blinkers somehow came loose and the wheel lock gear grabbed it, mangled it, and made it shoot sparks. It looks like it is just held in by some type of glue, I'm not surprised that the glue melted as hot as that area under the dash gets from engine heat.
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
