Odometer and trip meter not working
1 Post
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
My Odometer and trip meter seem to be stuck, this is in an 87 GTA (Not digital) I have it apart but Im looking for a thread with info on how to fix it.
Any help?
Any help?
1 Post
Car: 87 GTA t-top
Re: Odometer and trip meter not working
So I took the odometer apart , found the plastic gear thats riveted in the unit was broken.
I dont think there is a fix for this unless there is a special tool to remove it or in my case just use a spare odometer.
Engine: 4++,350 & 305 CIs
Yup, I just messed with one of my cars that did the same thing.. Only fix is a speedo shop, used or new..
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
I had the same problem a year ago and replaced the odometer with one from another car. It was a quick and easy swap and simple to set the new odo to the appropriate miles. Those plastic gears just give out over time and heat exposure. Mine came from a guy on this forum, check the parts listing and EBAY. You may need to get a whole speedo and take the odo out of it.
db057
08-11-2015 10:11 PM
