NHRA/IHRA BATTERY BOX FOR THE 82/92 camaros under $70 yes they Exist!
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Ya ever wanted to install a NHRA/IHRA Battery Box, in the spare tire Location,..and found that Nobody makes one that will/would fit!
and if ya did find one, Not going to...(ya I know)
and, every body and there dog (summit/jegs) wants $100 or more for 3 piece type that do not seal!
well cheeck this out sealed/vented and with 1/2" hold down rods!
and under $70 Shipped!
peekaaboo
and ya only need 3/8 hold down rods..but i asked for 1/2" rods
and yes the rods come out the bottom of the car and box, and hold every thing Nice and Tight!
peekaaboo
Re: NHRA/IHRA BATTERY BOX FOR THE 82/92 camaros under $70 yes they Exist!
http://www.ebay.com/itm/390369457503...S:1123&vxp=mtr
ya can send you the info.Link above i had mine made to order. total shipped was $65
made from alum plate thin/light Wt and made from 2 piece of alum when it's sealed it's sealed!! not like the over priced taylor stuff.
If ya want the same box. PM me.
and Ill send ya the size info.***posted below now***
His Name is Mark. The link shows a Higher Price. But he only charged me $65 for the custom Box.. he sent me a invoice and i paid it by paypal, skipping ebay
i think he takes Visa also
Turn time was about 2 weeks he makes alot of diff stuff
you can ask to have the cable holes on any part of the Box (ill drill and fit them My self)
this one for me is for the optima battery. i made out the size and shape. this guy filles the order the way you want..frign Fantastic! and his work is spot on!!! fits like a glove!
the only thing i added was the wing nuts.. he will send rods and nuts.and every thing els!
let him know the rods need to be 15" long (my size of Box) adjst for your size if shorter
getting a few guys looking so ill bring this post back up..
the box is the best Bank for the Buck Guys!
i have had 3 other battery boxs made with top names on them..this guys battery box is 100 times better!
My batter box size
you can use wood 1" x 1" strips to set the battery box on..i glued the wood strips to the floor
(walmart..shoe goo) till i got the size i needed. then did them out of alum sqr tubing
this makes the floor levl.
the battry box bolts will run from top to bottom coming out, under the trunk.
you can open one of the factry holes in the trunk floor. to run the vent tube out of. look close you will see two.. 1/4" holes
box bottom 7.1/2"inch wide..12" long
top is 8. 1/4" wide 12" long
box is 11" tall
this box fits the Optima batteries
hold down rods will be 15"inch long (let him know)
you can run the hold downs
end to end (fits best) see the pics in my post.
i also coverd the hold down with rubber hose...to keep pos and neg from playing with ea other.if i boo boo the car.. inside the box i use self stickey rubber sheet to keep the side turmls from also playing with the alum box.. just in case.. none of the other alum battery box makers think of this!..anyway
when clamped down it's rock solid.myself i install the Jump turmls nexed to the rear Plate on the car..so ill never have to open this thing...but if i have to..the wing nuts make it easy..
he will make any box you need..his work is Fantastic.
My batter box size
box is 11" tall
Car: 1988 Iroc Z
Engine: SBC 355 crate motor
Transmission: T56 6-speed
Axle/Gears: 7.5 stock Disc rear.
I realize this is an old thread but hopefully i can revive it. Im stuck with the same high priced, wrong sized problem with finding a battery box. The link that was given no longer works. Was wondering if those boxes are still available at all. cant seem to find anything.
will check with mark.
and see if he still making them. if he is will post hs info
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
sorry, old thread.. but its because i searched instead of making a new thread
just bought a taylor box today 48200 and was hoping it would fit. its about 1/2" toowide to fit in the spare tire well. any suggestions? can I cut/bend the piece of stamped steel that is in there...it doesnt appear to be anything more than where hte spare tire/jack was mounted too. but somehow its structural. i DEFINITELY want my battery hidden under the trunk plastic and not in the trunk floor well. ideas thoughts?
would like the box to be saled for NHRA rule 8:1 too
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
ArcticwhiteZ will that fit on drivers side too?
Car: 1987 IROC-Z
I installed the Taylor box in December
- I turned it to face this way (instead of sideways) so my 1 gauge battery cables could come into the box at a nice easy direction, and didn't have tight angles/bends to contend with
here is a link to the photo album of the whole project:
