Marshall gauges installed
Old Jul 30, 2012 | 09:56 PM
jimmy_pop15's Avatar
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
For anyone wondering what the marshall gauges look like in our cars, i just finished mine and installed it. I used the factory gauge housing but holllowed it out due to the depth of the marshall gauges and wiring. I also made a new faceplace out of plexi and blacked out everything but where the gauges and blinker indicators are. Looks pretty nice and fit well in the factory cluster, no hanging extra pods off to the side I'll post a few more pictures in the daylight later.
In the light
In the car
Blinkers and Hi-beam Indicators on
Old Jul 30, 2012 | 10:51 PM
Dwax13's Avatar
Car: 1986 Trans Am
Engine: Carbed 355
Transmission: Th700R4
Axle/Gears: 3.73 Posi
Re: Marshall gauges installed
Those look great man! what did you use to hollow out the back of the cluster?and how tough was it hooking them all up?
Old Jul 30, 2012 | 11:58 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Those look boss but I'm not digging the LEDs. They don't flow well with the blue.
Old Jul 31, 2012 | 04:42 AM
brando54009's Avatar
Car: 82 firebird
Engine: a few
Transmission: th350
Axle/Gears: wondering this myself
I dog em man, looks good unlike those over the top crazy multi colored ones everyone seems to like buying these days
Old Jul 31, 2012 | 06:45 PM
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
They're not that bright in real life. They don't stay on constantly theyre the indicators for the blinkers and hi beams
Old Jul 31, 2012 | 07:04 PM
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
The hollowed out original cluster. I just used a cutoff disc to cut the plastic
The gauges on mounted to a fabbed aluminum panel and wired up to a 12-pin connector(Radioshack $3)
The plexi painted so you only see the gauge faces and indicators. This was made to replace the original black plastic piece that holds the cluster in the dash
And the dash wiring rewired to connect with a female 12 pin connector (radioshack $3) Much more reliable connection than the factory design
Old Sep 9, 2012 | 09:03 PM
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
ok a little update on these gauges. One big con is the led lights the smaller gauges come with. Either the bulbs or the sockets are poorly designed and don't want to make a good connection. They tend to go on and off whenever they please. I took the bulbs out and tried squeezing the terminals on the sockets together so they'd hold the bulbs better. helped a little bit but they spread back out pretty much back to where they had started. One other problem is the fuel gauge. Some times it'll work fine, other times it just flicks around randomly, even though it's getting a constant reading with an ohm meter.
Old Nov 9, 2012 | 11:26 PM
sum_drummer_16's Avatar
Car: 1983 Z28
Engine: Lt1
Transmission: t5
Axle/Gears: 4th gen limited slip
hey, i'm gonna be getting these gauges soon, but i'm not sure about the wiring for the speedometer. I have an 83 camaro with a 94 lt1 in it and an 84 t5 with a mechanical sending unit and speedo. I can get my hands on a sending unit from a 92, but that still leaves me confused on how to actually wire it up. can i use the vss from the 92, and do i need to use the buffer? also if i do need to use the buffer, where is it? i've had the whole dash torn apart to redo wiring and thats something i've never come across
Old Nov 11, 2012 | 11:06 AM
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
any speed sensor will work with the marshall speedo. it only needs ground power and signal. it automatically calibrates to the sender's signal
Old Nov 11, 2012 | 11:13 AM
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
I just bought a regular gm sender off ebay 20 bucks
Old Nov 11, 2012 | 05:48 PM
Car: 1983 Z28
Engine: Lt1
Transmission: t5
sounds awesome. i really want these gauges, and that was my biggest concern. but if all i need is the sender, then thats awesome. that means i am definitely getting them for christmas
Old Nov 12, 2012 | 09:17 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I like the way they light up at night but Ive never been a fan of the gauges. Good job getting them in and making your own plate for them
Old Nov 16, 2012 | 03:50 PM
blakecharles's Avatar
These look just the the SCX red/blue line.
How are these in comparison to the Marshall SCX version? I don't need all the features of the SCX, but I do want them to be as bright...
Look at this video, these are the SCX gauges (they come in redline/blueline too). ARE YOUR GAUGES THIS BRIGHT???
http://s407.beta.photobucket.com/use...N0053.mp4.html
Old Nov 16, 2012 | 03:51 PM
you have any other pictures of these gauges lit up? also, it looks like you have a connector that will allow you to freely remove the gauges w/o cutting any wires. what kind of connector is that? where did you get it?
Here's another pic of the SCX, they seem to be the same as the LED's you have but with 180 degree sweep and alert indicators... I just cannot figure out if they have more lighting too.
Old Nov 20, 2012 | 01:14 AM
AceBoogie!'s Avatar
Car: Camaro SS
Engine: 5.7
Transmission: 4l60e
Axle/Gears: 4.10
badd ***
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
86IROC112
Aug 17, 2015 02:00 PM
