New Grant wheel
Old Aug 19, 2012 | 07:15 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
New Grant wheel
I didn't know I was looking for a new steering wheel until one popped up on the local CL here. It was hardly used and less than half price.
The leather on my original wheel was worn almost thru in a couple of spots.
I'm very happy with the results!
Old Aug 19, 2012 | 07:51 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: New Grant wheel
They are nice wheels, I have one too. Question is, how did you fit in the back seat to take the pics?
Old Aug 19, 2012 | 08:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: New Grant wheel
How did you connect the horn button?
JamesC
Old Aug 20, 2012 | 12:25 AM
Marine_Marauder's Avatar
Car: Black 1991 Z28
Engine: 5.7 TPI
Transmission: Automatic
Axle/Gears: I have no Idea
Re: New Grant wheel
JamesC
Connect the positive wire to the horn button, Connect the negative wire from the horn button to one of the bolts that attach the wheel to the hub to ground it.
I have the same wheel.
Old Aug 20, 2012 | 06:22 AM
JamesC's Avatar
Re: New Grant wheel
That's the way I have mine configured, but the horn is intermittent. Can't quite figure what the problem is.
JamesC
Old Aug 20, 2012 | 11:19 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: New Grant wheel
if the horn is intermittent then its something along the way to the horns as I had the same issue and it ended up being corrosion on the terminal the wire connects to the actuall horns was alittle rusty.
Nice wheel tho and I get one simular as well
Old Aug 20, 2012 | 11:26 AM
JamesC's Avatar
Re: New Grant wheel
Been there done that. Replaced the relay. Checked the horn switch. No apparent problems. Beginning to think the issue is in the column.
JamesC
Old Aug 20, 2012 | 12:30 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: New Grant wheel
Nice wheel. I have the 3 spoke version in my IROC. I sprung for the billet horn button and trim ring, which made a real big improvement to the overall appearance of the wheel.
Old Aug 21, 2012 | 03:52 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: New Grant wheel
Hank,
If you don't mind me asking, how much did you pay for the wheel?
Old Aug 21, 2012 | 08:48 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: New Grant wheel
Beautiful job, man.
I have the one with the chrome center button instead of black. I love it. I see you have the same mismatched clutch pedal pad that I have, hahahhaha.
As for the horn, that stupid plastic swash plate ring in the column was giving me an intermittent problem from before. I had to sandpaper the copper contacts on it, the spring loaded button, and the underside prongs but its good to go now. Hope that helps.
Old Aug 21, 2012 | 06:57 PM
HankL69's Avatar
Engine: 5.0 / 350
Re: New Grant wheel
So many questions so little time.........
Red Rock...... I fit in the back seat just fine, thank you, the problem is when I get in there I can't get out so, I opened the hatch and took the pic from the back.
James C........ I used the single wire in the install kit and connected it to the original socket on the steering column. The wire connects to the center connector on the horn button. The other connector does not get used (unless you have a Ford).
Arvizu9618......... The wheel is listed inYear One for $205. It is the genuine stitched leather cover. It was listed on CL for $100, I got it for $90. It was mounted for a short time in a project car and he desided to go a different direction. The posting was a week old when I saw it.
Old Aug 21, 2012 | 07:08 PM
HankL69's Avatar
Engine: 5.0 / 350
Re: New Grant wheel
Originally Posted by KrisW
Beautiful job, man.
I have the one with the chrome center button instead of black. I love it. I see you have the same mismatched clutch pedal pad that I have, hahahhaha..
I was really hoping nobody would notice that. The correct one is available so it will get replaced someday. I can't see it when I'm driving so not a big priority.
Old Aug 21, 2012 | 08:38 PM
JamesC's Avatar
Re: New Grant wheel
[QUOTE=HankL69;5358440James C........ I used the single wire in the install kit and connected it to the original socket on the steering column. The wire connects to the center connector on the horn button. The other connector does not get used (unless you have a Ford).[/QUOTE]
Humm, that configuration failed to work for me.
JamesC
Old Aug 22, 2012 | 05:20 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: New Grant wheel
I'm a little confused about this reply .It was asked earlier about the price of the wheel in the photos you posted. Is this reply you posted about the wheel in the photos ?
Old Aug 22, 2012 | 09:18 AM
Car: Black 1991 Z28
Engine: 5.7 TPI
Re: New Grant wheel
I paid about $200 retail from Grant. It's on their website.
Old Aug 22, 2012 | 01:38 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: New Grant wheel
New wheel looks great. I had a Grant wheel in my 72 Nova and loved it.
Old Aug 22, 2012 | 03:30 PM
Engine: TBI,5.0
Re: New Grant wheel
I found it on grants site and you have gotten a great deal,nice catch.
Looks great and probably feels even better(.Leather)
Mines the much less expensive one in the Challenger series.(rubber)I had to rap it in artificial leather(I beleave its called "pleather")Definitely not the same feel as leather but better than the rubber.
Old Aug 22, 2012 | 10:16 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: New Grant wheel
I need to wrap mine too. The rubber on these Grant GT wheels is a lot better than others I have had, though.
Old Aug 23, 2012 | 05:41 PM
HankL69's Avatar
Engine: 5.0 / 350
Re: New Grant wheel
JamesC
I did have a problem when I first hooked up the wire included in the Grant installation kit. When I first tried grounding the wire to the wheel to check for contact, there was nothing. I thought it might be too large for the tube that it fits in so I filed it down a little and that seemed to do the trick.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
