Question about gauges.
Old Sep 9, 2012 | 06:56 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Axle/Gears: limited slip disc
I've been having problems with my gauges reading wrong. First my temp gauge reads 20-30 degrees above what the scanner shows. Second my voltage gauge reads under the 13 volt mark while the scanner shows 13.4-13.9 volts. Has anyone had this problem? Any ideas about how to fix it?
Old Sep 9, 2012 | 06:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Question about gauges.
Sounds like they're working just fine.
Old Sep 9, 2012 | 07:00 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
It would be nice if they read a little closer to what the ECM is seeing.
Old Sep 9, 2012 | 07:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The gauge sender reads temperature in a different place than the ECM sensor, and the gauges are hardly precision instruments. They're not meant to give an exact value, they're to let you determine when something unusual is happening.
Old Sep 9, 2012 | 07:12 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
I know about the temp sender and the sensor. My problem is that the gauge reads in the red before the radiator fan even comes on. I have noticed that every once in a while the volt gauge will go up to near 13 volts and the temp gauge will start to show close to what the scanner shows, so I'm wondering if there is a bad ground or power wire to the cluster.
Old Sep 9, 2012 | 07:15 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I don't think there is a real fix to these.. They definetly aren't precision gauges.. There is no adjustment that can be made to them that I am aware of.
Old Sep 9, 2012 | 07:23 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
You might think about getting an after market mechanical temperature gauge, it might help your piece of mind.
Old Sep 9, 2012 | 08:58 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
It's also possible that your gauge pod printed circuit board is on its way out.
Old Sep 9, 2012 | 09:30 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Is there a way to test/repair if it's going out?
Old Sep 9, 2012 | 11:27 PM
majobis's Avatar
Axle/Gears: G92
It's a pain in the butt, due to having to disconnect the speedometer and taking the pod out. However, once I had, I discovered corrosion in two small spots. See the photo for an example.
Old Sep 10, 2012 | 08:06 AM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Thanks! Any pointers for removing the pod?
Old Sep 10, 2012 | 10:44 AM
majobis's Avatar
Axle/Gears: G92
Take off the dash pad
Remove gauge bezel Torx screws and remove bezel
Remove clear gauge protector lens
Remove bolts holding in gauge pod
Remove some of the plastic trim under steering wheel
Disconnect speedometer cable
Pull out pod carefully and unplug two connectors
Pod can now be removed
Do some searching if unsure how to remove or disconnect thing like the dash pad or speedometer cable. Member JamesC showed some good photos.
Old Sep 10, 2012 | 12:10 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Thanks! Pictures would be great if anyone has some.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
