86 firebird fastback help
Car: 86 firbird, 2003 police interceptor
so my bird has a 85mph speedo. i am wanting to put in a 140. what do i need to do to make it work? also it has a 305 with a quadrojet. was told it was a pontiac motor. is it just a sbc or are the different?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: 86 firebird fastback help
3rd gen f-bodies use corporate small blcoks, so your 305 is the same as camaros 305.Which is the same 305 in G bodies & other GM products.
As for the speedo.Not too sure, but in camaros its a simple swap.Provided you stick w/ mech-mech & elec-elec speedos.Converting from mechanical to electric is a little more involved.
ok. good. that helps alot. the motor has about 70k on it. im wanting to install roller rockers. then next month the intake and carb. no motor issues at all. any ideas on what type of rockers to install? also i intend to install new lifters and pushrods when i do the intake. so rollers will only be in for maybe 100 miles. and tips? o. i am also installing a gear drive billet dist.wires and everything
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Welcome to the forum!
You should ask all these questions in the general engine or carb forum, not interior.
But you won't need to ask, just search because all your 305 questions have been asked before.
I think if you read a little first you will see you re starting in the wrong direction with your motor.
There are also many threads already about swapping speedos.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
All you need to do it pickup the 140mph pod, it will have the 8k tach as well, and just swap them over, totally plug and play.
To do it right, you need to swap the odometers between the two pods so the milage stays the same.
It all unbolts with basic hand tools.
Car: 86 Trans Am
there are no aftermarket gauges to direct fit in the car (firebird). Used to be some digital setups, but they are long gone.
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
