power locks not working
Old Oct 12, 2012 | 11:17 PM
mack1985transam's Avatar
Car: 1985 trans am
Engine: 355 vortec built 4 bolt main
Transmission: 700r4 w/ shift kit b&m console mega
Axle/Gears: 3.08
I have a 1985 trans am and the power locks are not working. I have new actuators and they are working good. It seems to me there is to much play in the linkage where the oval shaped unit connects to the locking rod. The actuators are moving great but the rod is moving little to none at all. I don't know what this would be in I have greased all the linkage and everything. Like I said I think it is in that oval shaped unit what ever its called. But is the suppose to be any spring or anything in that unit maybe a retaining clip?;
Old Oct 14, 2012 | 06:53 PM
Car: 1985 trans am
Axle/Gears: 3.08
Re: power locks not working
Anyone?
Old Oct 15, 2012 | 03:58 AM
Faded's Avatar
Car: '91 Firebird
The rod is probably bent. Straighten it out.
Old Oct 15, 2012 | 08:18 AM
Car: 1985 trans am
Axle/Gears: 3.08
already circled that its straight I would have noticed it bent
Old Oct 17, 2012 | 11:36 PM
Car: 1985 trans am
Axle/Gears: 3.08
Any help would be appreciated
Old Oct 18, 2012 | 02:48 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
Can you get a picture of what you're talking about. I will try and remember to pull up an exploded view of the doors when I get a chance.
Old Oct 18, 2012 | 06:30 AM
Car: 1985 trans am
Axle/Gears: 3.08
Yes I can do that
Old Oct 22, 2012 | 11:38 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
This is the best I can do. Maybe you can at least name the part you think it is and someone can help.
Attached Thumbnails power locks not working-10-40.gif   power locks not working-10-41.gif
Old Oct 22, 2012 | 08:29 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
I had a problem with the passenger side not locking. It was the rod/actuator sticking a bit. To the far right side on my pic. I took a lubed up long q-tip thingie to the connecting points which freed it up nice.
Old Oct 22, 2012 | 08:58 PM
Car: 1985 trans am
Axle/Gears: 3.08
I think I might be missing #39 can you show me a real life pic of that?
Old Oct 23, 2012 | 11:05 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The problem is caused by excessive friction on the rod that runs horizontal and slop in the plastic linkages that connect the rods. Early F-bodies had a expanded plastic mesh that the horizontal rod runs thru behind the inner door panel. They changed that to a plastic clip that pops into the door. The rod snaps into it. You can solve the slop in the plastic linkages by wrapping it with a zip-tie at a 45 degree angle.
Lon
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
