Seat Belt Guides/ Escutcheon Questions
Old Oct 28, 2012 | 07:10 PM
ZChaseman's Avatar
Car: 1986 IROC-Z Camaro
Hey I recently bought a pair of seatbelt guides on ebay for 10.00$ and was wondering if you need the escutcheon ( i think you do ) or not. Also, how do the guides stay on the seat? Thanks!
Old Oct 29, 2012 | 11:39 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Seat Belt Guides/ Escutcheon Questions
If its a FireBird ,I would use the escutcheon,it will only pull on the headliner and ruin it.Again if it's a Firebird,the seat guides attach to the headrest with Two screws.Like this.
Old Oct 29, 2012 | 04:22 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
If we're talking about these things then yes, use them.
Old Nov 6, 2012 | 06:22 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Um, question? How does one get those things OFF of the belt? The belts in the 87 didn't have any, period. I have a pair of black ones now that the passenger's side has it (I keep having to reattach it to the retractor to keep it out of the way), but the driver's side is missing it. They're one piece, no way to slip the belt out, right? So I'd have to cut one (or 2, probably get a red pair or something)?
I mean the guides on the headliner... I have plenty of seat back loops, in at least 3 colors .
Old Nov 6, 2012 | 08:40 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
The upper rear factory plastic trim pieces are put on thru the belt. IDK but in another thread a year or so ago, someone mentioned a piece snaps onto the mechanism, then the trim piece snaps onto that. So IDK about that piece, ours didn't have them, just the trim.Piece
Hope someone can clarify that!!??!!
The trim piece can be bought aftermarket that has a slot to slip the belt into.
Again, I forget who has them-- maybe Hawksthirdgen, Ricks, Moderndaymuscle???
If yours doesn't stay in place, look for busted tabs..
Old Nov 6, 2012 | 08:50 PM
Car: '87 Camaro
To get ours off, I cut them just using a hacksaw blade. Ours had busted tabs & would always fall.
If your tabs are busted, carefully pull it down, & VERY CAREFULLY cut a slot to slip the belt belt out.
OR disassemble the belt & slide it off.
If I can find where to get the trim I'll post the link.
Old Nov 6, 2012 | 09:02 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The passenger's side had the problem that the metal retainer tabs (on the retractor housing) were bent. I took and separated the housing (those retainer tabs were bent as well ) and straightened the tabs so the guide loop stays in place now. But I still haven't figured out how whomever got the driver's side loop off, or why (bought the belts used from a guy on here). Must have broke at some point, I guess.
Old Nov 6, 2012 | 09:17 PM
Car: '87 Camaro
Here's the link--
IMHO, please read the entire thread, there are a couple good points brought up. There are a few pics of the trim pieces with the slots made into them.
https://www.thirdgen.org/forums/inte...retractor.html
Good to know you fixed it Maverick H1L!!
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
redmaroz
Aug 16, 2015 11:40 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
