Squeaky Interior?
Old Oct 28, 2012 | 10:54 PM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
Squeaky Interior?
Hi, Im Jake. My 1992 Camaro RS has an interior thats kind of squeaky and rattly, also when i push on the breaks the dash pad likes to bounce up and down. The squeaks and rattles sound like they are coming from underneath the hatchback, does anyone know what they might be and how I can get rid of them? Thanks.
Old Oct 28, 2012 | 11:11 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Re: Squeaky Interior?
Good luck. These cars are notorious for squeaks and rattles, especially the higher mileage cars. All you can do is start to isolate 1 noise at a time and fix it. Then move on to the next one. It's a pain but so worth it.
Old Oct 29, 2012 | 12:08 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
https://www.thirdgen.org/forums/body...servation.html
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I replaced everything in my car and it still rattles like a bitch. Used little rubber washers in certain areas and it helped abit
Old Oct 29, 2012 | 10:38 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
i went through my door panels and replaced the weather stripping, new door cards, added fatmat, new door handles on the inside and outside... and it still squeaks and makes all kinds of noise.
Old Oct 29, 2012 | 10:23 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Regarding the dash pad, check the pad cut outs for the defroster to see if the Phillips screws are still present. Under the lip of the pad, there should be a series of bolts securing it to the dash.
Old Oct 30, 2012 | 09:24 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
I'd say most noises come from the hard plastic pieces, they don't fit very well, especially in the dashboard.
I've found some thin adhesive foam that I used between the different panels. It reduced the noise quite well. Neoprene might be a good thing too.
Old Feb 19, 2013 | 05:24 PM
Limpperi's Avatar
Car: 1991 Formula 350
Engine: 350 TPI (L98)
Axle/Gears: 3.23 Posi
whoa, mine does not rattle at all! not even slightest rattle. unless I play music extra loud with my subwoofer. then the plastic panel next to passenger side backseat rattles. maybe lm just lucky 80k miles.
Old Feb 19, 2013 | 05:54 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I can't hear any squeaks in my car...but I do keep my radio at "11"
Old Feb 23, 2013 | 05:02 PM
thewhitestripes's Avatar
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
I battle this issue monthly with my 250k iroc.... A squeaky exhaust came from the catalytic converter touching against the brace right above it. The rattling dash is because a few screws and one Philips screw by the deforest vents was missing, another dash rattle was because on of the ducts leading to one of the two small vents closest to the windows wasn't tight to the dash. A slight transmission rattle because the speedo cable fastener on the side of the Trans came lose. A high pitched wine came from my clutch hydraulic bar thing resting against the lever that transfers the pressure to the pilot bearing (needed to be greased) the center console will instantly start rattling if one of those star key bolts loosen up. When everything in the rear isint greased up you'll get sqweeks while you drive also. Because theses cars are so old and utilize old technology EVERY little screw and bolt needs to be nice and tight. (at least in my sat it does) this spring I'm stripping the interior down completely and hitting it with some por15, dynamatt, neyoprene, and carpet with mass backing. Im so sick of all these little rattles. But a cheap fix is cranking up the stereo lol
Old Feb 23, 2013 | 11:03 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
On my Camaro 'vert I used Dynomat to kill panel vibration. Disassembled plastic panels and used Goop on the panel fitment areas, then reinstalled the screws. I used 3M trim adhesive (yellow color) on all the screws before installing them so they'd stay tight longer. Also did the fixes to the inner door panels and used zip ties on the plastic parts hinge that link the rods.
Lon
RyanJB
May 7, 2016 06:23 PM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
