Will I still need the ecm if i use aftermarket gauges for my 4th gen dash swap?
Old Nov 29, 2012 | 06:23 PM
xMrBadDogx's Avatar
Car: 89 Camaro RS 2.8 V6
Engine: 2.8 MPFI V6
I'm planning on getting aftermarket gauges, and seeing as how my car has mechanical gauges (right? its an 89 so it should, am I right?) i don't want to go through the trouble of changing to electronic. If i do that could i just wire all the controls my car into the dash (e.g. AC, lights, etc) without the ecm?
Also, ive been looking for a thread I found way back that listed all the parts im gonna need to pull from the 4th gen, can someone link it to me? I cant find it. Thanks.
Old Nov 29, 2012 | 06:28 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: Will I still need the ecm if i use aftermarket gauges for my 4th gen dash swap?
Probably.
Old Dec 25, 2012 | 11:21 PM
rs89todd's Avatar
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
i just got an 02 cammy dash, mines an 86 i have no computer in my car but i want to get the cluster working if i could, i know ill need the signal generator like listed below, but i figure ill need an ecm, i did not get it as was gone with motor.
i suppose my questions are, 1 which ecm will work? like anything with vss and up?(91-92?) and i dont plan on using the computer for anything but the speedo and im not a car computer guy so will it work correctly?
http://www.hawksthirdgenparts.com/pr...nsmission.html
Old Dec 25, 2012 | 11:28 PM
rs89todd's Avatar
Engine: 355 chevy
Transmission: t-5
with my dash i made sure to grab the main dash of course, but theres a brace you wanna make sure you grab and not leave it behind, save pigtails, the a pillar pods, the lower dash pieces, fuse pannel cover, kick pannels, dash pad, hood release if you want it to work, and recommend console while your at it.
door pannels im iffy on, i see one post where the guy looks like he did it successfully, but i hear that for the most part they dont work, so if you think you can do it and get for a decent price id go at it imo
Old Dec 26, 2012 | 05:01 PM
xMrBadDogx's Avatar
Engine: 2.8 MPFI V6
Thanks, theres a sale this weekend at the junkyard so ill be sure to try and find a 4th gen with all the parts
Old Dec 27, 2012 | 09:33 AM
rs89todd's Avatar
Engine: 355 chevy
Transmission: t-5
let me know how you make out, and i never have yards close enough for me to just go look, hopefully you find what you need, and grab the style you want, id recommend, 93-02 firebird or 97-02 cammy, let me know how you make out
ill probably go the sam way you are about it with mechanical gauges, but im not going to be using a computer till i get a 6l or ls1, should keep in touch and help each other out
Old Dec 27, 2012 | 09:36 AM
rs89todd's Avatar
Engine: 355 chevy
Transmission: t-5
https://www.thirdgen.org/forums/inte...dash-swap.html
this will help too
Old Dec 28, 2012 | 05:17 AM
xMrBadDogx's Avatar
Engine: 2.8 MPFI V6
Already looked at it, but thanks
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
