What LEDs for gauges?
Old Jan 5, 2013 | 08:29 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
I'm trying to do red LEDs for my gauges in my 92' camaro but I'm trying to figure out which ones. I used ones like these -
Amazon Amazon
But they weren't anywhere near bright enough. What ones should I be using and which ones are the brightest?
Old Jan 5, 2013 | 11:37 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: What LEDs for gauges?
Super brights are really good and brigh but ive never used red before
Old Jan 6, 2013 | 03:58 PM
MeenZ28's Avatar
Transmission: A4
Yes, but what type? I've tried the search funtion of the board and they all say superbrightleds.com but dont say what bulb specifically.
Old Jan 6, 2013 | 05:24 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
194 bulbs. They plug right in.
Old Jan 6, 2013 | 05:28 PM
RavageTheRoad's Avatar
Car: 1991 RS
Engine: L69?
I'm gonna be doing this too. From what I've read on here, get at least 4 diode LED at at least 90* angle or more. There is only 4 bulbs for the backlighting so you need a wide angle. I'm probably gonna go with 120* for the backlighting and 90* for the other ones.
And paint the light blue area in back white/silver or put in tin foil so they reflect better.
Old Jan 6, 2013 | 05:42 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
194 bulbs are not led these are fact tuyp bulbs. and dint come in red.
Old Jan 7, 2013 | 01:03 PM
6SIX6's Avatar
Car: 89 IROC
These are what I used in my stock gauges and now my autometer gauges
http://www.ebay.ca/itm/20X-T10-158-1...dd2ccc&vxp=mtr
OR THESE
http://www.ebay.ca/itm/2-x-super-Whi...item56513c13b1
This is a pic of my autometer gauges and how they look. I used the 2nd link for my gauges it just all depends on how bright you want them
Old Jan 7, 2013 | 02:42 PM
MeenZ28's Avatar
Transmission: A4
Are they bright?
Old Jan 7, 2013 | 03:56 PM
6SIX6's Avatar
Car: 89 IROC
thats a night shot in my garage with the interior light on and they are really bright as you can see
Old Jan 7, 2013 | 05:46 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
This is what i meant by 194. This is an led 194 replacement.
http://www.superbrightleds.com/morei...edge-base/199/
Old Jan 7, 2013 | 06:20 PM
Car: 1990 z28
Engine: 5.0
do a search for white gauges . they tell you what leds to use for your cluster.
Old Jan 18, 2013 | 11:08 PM
basshead208's Avatar
Car: 86 IROC Z28
Axle/Gears: posi 4 disc 2.73
go to ebat and type in ( T10 5050 red led)
Old Feb 19, 2013 | 02:53 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
OR THESE
How much did it cost to change the gauges to autometer and how hard was it? I need to do that
Old Feb 25, 2013 | 09:52 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
194 defines the style and base of the bulb not the lighting element. A 194 is a wedge base bulb either led, incandescent or whatever else there may be. Just like a 1156 and 1157 are both bayonet base bulbs but the number means either a Doble base or single base.
Anyways, with a shine through Guage style like on newer cars where a reflection plate isn't used you might want a 6 diode to insure brightness. Also the color of the numbers and notches may affect the lighting with some bulb colors. Most cars have a blue tint on the gauges and when mixed with a yellowish tint of incandescent bulbs it becomes green ( think back to elementary school with mixing colors) so you may get a more purple color if you don't remove the tint. IMHO go for 6 diode bulbs, test them with the tint on and if purple just use a sewing needle to scrape off the tint. It's tedious I know, but trust me, red is worth the work, I always get comments about my red lighting.
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Luigytico09
Oct 1, 2015 08:46 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
