90-92 Camaro odometer....spinning backwards?
Old Jan 18, 2013 | 03:49 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
This is not a thread on how to reset the odometer, i got this cluster from a friend who pulled it out for the weirdest problem, the odometer/trip spin in reverse?! I cant find any info on the disassembly of these units so if someone has a link to a thread on how to take the cluster apart i would appreciate it, ive ripped up plenty of the 80's style ones but im iffy on just diving into this modular style one. Im hoping it will be a simple fix because my current cluster needs a tach fix and the trip reset stalk is snapped off.
Has anyone come across this? Any info on the cluster disassembly would be appreciated
Old Jan 18, 2013 | 05:25 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 90-92 Camaro odometer....spinning backwards?
It seems like someone messed with it in the past (probably to fix the trip odo) and connected the 2 wires running to the odo motor backwards. There are probably (I know about the Bird clusters but not sure on the Camaro clusters) 2 black wires running from the odo motor to the drive board, which connect to 2 pins sticking out of the drive board. Try reversing them first.
Old Jan 19, 2013 | 01:13 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I found a 4 pin plug that attaches the assembly into the PCB, I see no identifying marks of any kind on which direction it would go, I can see easily how it could be reversed
Out-Cast
Mar 22, 2019 09:39 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
squiggy2
Aug 9, 2015 09:30 PM
gwade12
Aug 8, 2015 08:17 AM
