Help fellow verts with seat belts
Subscribe
Jan 31, 2013 | 04:50 PM
Convertible seat belts
Hey guys so I just had had my rear seatbelts redone but can't remember how the ones on the tonneau caver go. I can't tell which one is left or right cause the mechanism is same but the way they. We're done I have one weight on front side and the other on back side doesn't seem right is there any pictures out there or that someone can send for reference please only the one the tonneau cover
Second I tried taking front ones off but broke my torque bit because it was on too tight any suggestions what else I can use
Please if u can help posting some pics of the rear ones or email them so I can finish installing them thanks guys
Hinlook@aol.com
Reply 0
Jan 31, 2013 | 07:30 PM
Re: Help fellow verts with seat belts
Camaro or Firebird? Year? Would help get an answer that matches your vehicle.
Reply 0
Jan 31, 2013 | 08:38 PM
90 rs camaro convert. Need the ones on tonneau cover
Reply 0
Jan 31, 2013 | 09:03 PM
I have a 91 TA and don't know whether there is any differences. Maybe a Camaro member will help you. Sorry.
Reply 0
Jan 31, 2013 | 09:18 PM
Do you have belts that attach on cover
Reply 0
Jan 31, 2013 | 10:35 PM
Yes. The shoulder harness mounts on the bottom of the tonneau cover and the lap belt is anchored in the arm rest on my 91. The buckles interlock together and secure in a latch that is at the side of each seat cushion. It is a 2 piece belt setup.
I don't know if this is the same as yours and my car is laid up with some other "winter" repairs going on about 30 miles from me. I'll keep an eye on this thread and, if no one has helped before I go to my garage, I'll look at mine and see if I can answer your questions. I'll probably be there within 2 weeks.
Reply 0
Feb 1, 2013 | 09:59 AM
Hey those sound like mine. Ya when ever you have time is cool maybe I'll get lucky and someone else will help me. The problem I have is that they are both the same so nothing to distinguish left from right the only thing I can think of is if both weights are facing front of car or rear will determine there placement I thine the guy who did them for me made that mistake and sewed the the same way so both be facing the same therefore making it only for one side. Thanks. U can email me to. Hinlook@aol.com
Reply 0
Feb 6, 2013 | 06:25 PM
I'll be working on my car in the next few days and I will take some pictures of my belts for you. I am not sure what you are calling the "weights". Can you tell me? Do you mean the pieces that are on the end of the belts that connect the shoulder belt to the lower seatbelt when you buckle someone into the seat?
Reply 0
Feb 6, 2013 | 07:03 PM
Hey I appreciate that if u text me ill text u an example
7026046512
Reply 0
Feb 6, 2013 | 07:30 PM
Sorry, I do not text. Pic's will be posted here or in a PM to you.
Reply 0
Feb 6, 2013 | 07:32 PM
You have an email I can send it to u
Reply 0
Feb 8, 2013 | 04:34 PM
I have attached pictures of seat belt
thanks They are the ones that mount on tonneau cover
Reply 0
Feb 8, 2013 | 07:49 PM
Both belt ends should have the connecting piece pointing down when mounted. It looks like yours have one up and one down causing the one to require twisting to mate with the bottom belt.
I was working on my car today and snapped some pictures. I'll send them to your email account since I think they are too big to post here.
Reply 0
Subscribe
