How on earth do I remove this peice?
Old Feb 10, 2013 | 06:36 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I've been trying to remove the whole rear quarter panel plastic trim with the cargo box but there's that black metal thing that the rear seat clamps onto that is getting in the way. I've tried unscrewing it but it won't budge at all, anyone know how to remove it?
Old Feb 10, 2013 | 06:43 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Re: How on earth do I remove this peice?
Use the appropriate size torx bit, I used one for a 3/8" socket set and use a small breaker bar if it is stuck but be careful not to break it.
ryanmorrison1's Avatar
Car: 87 camaro z28
I believe theres a torx on the end of it mine just screwed out
Old Feb 10, 2013 | 07:29 PM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Yeah, it's a TORX bolt. It may be the same size as the bolts for the front seatbelt receivers, which is a T40 That I recently had to removed on my car. It may take some force to break it loose, make sure the TORX bit seated firmly in the bolt head. I had to tap the bit in lightly with a hammer to get it firmly seated in the bolt so it wouldn't strip out.
Old Feb 12, 2013 | 03:22 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I would recommend this as well. If you round off a torx bolt this big, there's no getting it out. I would also recommend using a very long ratchet or breaker bar. The factory torques these to 150 ft lbs or something ridiculous.
IIRC, the front (and rear) seatbelts are a T47...T40 would be for the intake/serpentine setup bolts on a TPI car. I would guess this rear seatback mount to be a T47 also.
Old Feb 12, 2013 | 04:26 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
If you have a spair one use a pair of visegrips ,and the torx bit at the same time .
Old Feb 12, 2013 | 05:18 PM
Axle/Gears: 3.45
Thanks guys! managed to get it out
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
