4th gen console into a 3rd gen GTA - PLEASE ENTER !
Old Feb 19, 2013 | 08:24 AM
TX-SleeperC5's Avatar
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
I've seen several threads of 4th gen consoles into 3rd gen Camaro's but no firebirds.
Has anyone here installed a 4th gen "AUTOMATIC" console into a 3rd gen Trans Am GTA ?
Looking to do this swap on my son's 87 GTA since his current console is getting harder to find repair/replace parts and pieces for. Any pics of you work would go a long way and would be greatly appreciated.
Post up what you've got or done.
His GTA....
Old Feb 19, 2013 | 09:16 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: 4th gen console into a 3rd gen GTA - PLEASE ENTER !
Here ya go......
Old Feb 19, 2013 | 09:29 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
it would be the same as doing it in a camaro but try to find a firebird dash IMO they look better anyways
Old Feb 19, 2013 | 09:33 AM
Engine: 5.0 TPI
Originally Posted by heat seeker
Here ya go......
That looks SWEET !! What is that console out of and where can I find a shifter similar to that one ??
Thanks for posting !
Old Feb 19, 2013 | 09:44 AM
Car: 89 Formula
Engine: 383 SBC/HSR
No problem.....here's the thread where I posted info on it.
https://www.thirdgen.org/forums/tran...e-ratchet.html
Old Feb 19, 2013 | 09:58 AM
Engine: 5.0 TPI
So does the console bolt up in roughly the same place ??
Old Feb 19, 2013 | 10:07 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Yes, the console bolts up using the existing holes. It's the shifter that requires you to do cutting and shimming to get it to the correct height.
Old Feb 19, 2013 | 10:15 AM
Engine: 5.0 TPI
That's great !
So from the looks of it, the shifter is bolted to the floor and then the console is trimmed and placed "over" the shifter, correct ?
Old Feb 19, 2013 | 10:24 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Yep, you got it. The B&M shifter won't fit in the existing holes. Those have to be drilled to align/center it with the new console.
It's definitely a custom job, but when it's all said and done it looks really good.
Old Feb 19, 2013 | 10:40 AM
Engine: 5.0 TPI
Well I guess it's time to start chasing down a 4th gen console and have my son choose which shiter he wants.
Old Feb 19, 2013 | 10:57 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Choosing just any shifter may not work. The height of the shifter is critical, 4th gen cars have less room height-wise than our consoles. I can only vouch for this shifter, b/c it's the only one I've tried.
Just a heads up.
Old Feb 19, 2013 | 12:14 PM
Engine: 5.0 TPI
Just a heads up.
Thanks for the heads up !
Believe it or not he likes the same one you have and his other choice is the black "stealth" version of your shifter.
Old Feb 19, 2013 | 12:33 PM
Car: 89 Formula
Engine: 383 SBC/HSR
Yep, the stealth is really nice also. Hope it works out.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
