digital cluster installation
Old Feb 20, 2013 | 03:21 PM
87tunedport's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0
ok im basically asking this to the guys who have this cluster in their dash last week i pulled my original unit out to replace some bulbs and long story short as i was putting it back in i damaged it and no longer gave me oil/temp/alt i ordered a replacement cluster and was trying to figure out how to put it in without damaging the new one. my buddy told me i should drop the column a little to allow more clearance (i have tilt and its pretty tight trying to work it in) would this work? how do i do this? or does anybody have any other suggestions to try? i do know its oddly shaped and pretty hard to get in there. thanks in advance guys
Old Feb 20, 2013 | 04:45 PM
Panther1's Avatar
Re: digital cluster installation
2 bolts about mid column (underneath) will allow you to drop a little or will put your steering wheel on the seat depending on how much you loosen them
Old Feb 20, 2013 | 09:01 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Take the dash pad off also,then you'll have plenty of room.
Old Feb 21, 2013 | 08:11 AM
Engine: 5.0
ok i will try to take dash pad off, i dont know why i didnt think of that before. also doe the steering column have any wires that will interfere with it lowering?
Old Feb 21, 2013 | 11:25 AM
mantaguy's Avatar
Engine: 5.0 EFI
You really don't need to touch the steering column,just tilt it down!!!
Old Feb 21, 2013 | 06:01 PM
Engine: 5.0
thanks for the info guys i got it in i took dash pad out and had to lower column just a little but it slid in and out like butter and no damage was done to the new one
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
ChevyZ71
Aug 13, 2015 07:30 AM
