Steering Colum and Ignition Question
Old Feb 24, 2013 | 07:26 PM
Cars'n'Guitars's Avatar
Car: 1985 Camaro Iroc-Z
Engine: Currently Deciding
Transmission: TH350 Built
Axle/Gears: 3.73 POSI
Okay so I have a major problem with my car it's really not a major problem right yet but will be when there is a running motor back in it. My ignition is always unlocked and can be in all positions regardless of if there is a key in it or not. It can be off, running, and starting positions without a key. What is the problem and how can it be fixed?
Old Feb 25, 2013 | 12:10 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: Steering Colum and Ignition Question
There is either a problem with your ignition cylinder(worn out) isn't engaging the lock mechanism, or it is possible something is broken in the pieces that engage the lock plate.
Either way you will have to remove the steering wheel, then the problem will probably present itself. In any case, it shouldn't be a big deal to fix.
Old Feb 25, 2013 | 06:45 PM
Okay I'll look after the motor is swapped in. What kind of broken stuff would I be looking for in the steering colum?
Old Feb 27, 2013 | 11:43 AM
Joe Tag's Avatar
The lock cylinder is most likely the problem it should lock no matter whats wrong in the column. Zane is right, you will have to pull the wheel, ten there is a black torx screw that holds the cylinder in. Auto Zone rents pullers for nothing. Just a deposit then returned when you return the tool as you got it. DO NOT TRY TO USE A HAMMER!! You will booger up the threads on the shaft and cause more problems.
Old Feb 27, 2013 | 01:52 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Try getting some lube from a hobby shop or something... Could just be the tumblers inside are frozen in place for whatever reason.
Old Feb 27, 2013 | 08:20 PM
Okay thanks guys.
Old Feb 28, 2013 | 08:04 AM
1Aauto's Avatar
Former Sponsor
We carry new ignition key lock cylinders. I have them in different colors too. Here's a link to them on our website.
Chevy Camaro Ignition Key Lock Cylinder
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 23, 2015 06:33 AM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
