LED Interior Lighting.. Help with wiring!
Old Feb 28, 2013 | 04:03 PM
Lil_Redd_Camaro's Avatar
Car: 1986 Camaro
Engine: 2.8L MPFI
I want to put some LED's in the foot wells and on the under side of the dash, but where would I run the power so that they come on when I turn on the driving lights? I can get to the lighting switch, but what wires do i go into? I have a 86 Camaro with the 85mph cluster and no fog lights.
Old Mar 1, 2013 | 05:15 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: LED Interior Lighting.. Help with wiring!
It'll be a gray wire
use a test light to make sure you get the right one
good luck
Old Mar 1, 2013 | 05:30 AM
N_da_Mood's Avatar
Car: 1992 Z28 Heritage Edition
When I did mine I used the wire from the stock stereo that would light up the buttons when the headlights are turned on, took a while to find the wire, because the previous owner tucked it away, but it did the trick.
Old Mar 1, 2013 | 08:19 PM
Car: 1986 Camaro
Engine: 2.8L MPFI
Awesome thank you!
Old Mar 4, 2013 | 03:50 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
I would just want to suggest that you don't put them on the driving lights switch. It may be nice now, but after a while those lights can be a pain to see past and you don't always want them on. My buddy wanted to do the same thing and I talked him into running the power off an ignition powered fuse, with a toggle switch to engage them. This way you can have them on day or night as long as the key is turned, and turn them off with the toggle. Just my 2 cents.
Old Mar 4, 2013 | 09:57 PM
Car: 1986 Camaro
Engine: 2.8L MPFI
What I went ahead and did was ran them off the driving lights, but put a toggle switch on the ground so I can turn them off if I want, but they will still come on with the driving lights. Thanks for the advice though!
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
