window sealing problem
Old Mar 6, 2013 | 06:48 PM
landon360's Avatar
Car: 1986 iroc-z
Engine: 350 tpi.
Transmission: 700r4 with shift kit
Axle/Gears: stock gearing
my driver side window when i roll it up it doesnt seal right, it wants to push out too far and go past the rubber seals and stick out a little bit. anyone know what it could be??? i need help ASAP
Old Mar 6, 2013 | 09:29 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: window sealing problem
With the door-panel off, can you flex the window-regulator to cause the window to seal better?
If so, can you re-position/bend the regulator mechanism in a permanent manner?
Old Mar 7, 2013 | 06:41 AM
landon360's Avatar
Car: 1986 iroc-z
Engine: 350 tpi.
havent had the time to remove the panel, when i want it to seal right, i can shut it from the outside and push the window in as i close the door and it seals right then but when i drive it and shut the door from the inside i cant pull on it from the inside and it sits past the seals and out a little
Old Mar 7, 2013 | 07:40 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
You will need to take the panels of and experiment with the guides.
There are two metal parts with felt on them, that either push the glas in or let it stick out a little more.
IIRC, they are mounted on the top of the door when you remove the panel and I think the trick was pushing them outwards causes the glass to come in further and moving them inwards causes the glass to move outwards.
So you would need to move those mounts slightly outwards. If that doesn't do the trick, it's gonna get awkward with about all of the other possible adjusting screws within the door and there's some work ahead of you.
If you can find the t-top leak guide on the boards: All info is in there. Even if you don't have t-tops.
Old Mar 7, 2013 | 07:43 AM
W.E.G.'s Avatar
Engine: V6 2.8
...which I believe is this part:
http://www.hawksthirdgenparts.com/pr...et-New-GM.html
Old Mar 7, 2013 | 07:45 AM
W.E.G.'s Avatar
Engine: V6 2.8
...which there is one at:
https://www.thirdgen.org/ttopleakfix
...but doesn't seem to address the doors issue
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Dialed_In
Aug 20, 2015 01:45 PM
Firebird sweden
Aug 16, 2015 05:02 PM
