Inner Window Sweep Removal
Old Mar 29, 2013 | 10:21 PM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
How do I get the inner window sweep mount screws out? Mine screw into the door and I don't see a way of getting a screwdriver in there...Don't want to mess up the sweep.
Did a search but didn't come up with much.
Old Apr 1, 2013 | 01:29 PM
86TA355SR's Avatar
Re: Inner Window Sweep Removal
Has anyone came across this before? I can't get my door panels off with the sweeps screwed into the door....
Old Apr 1, 2013 | 06:16 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
Are you sure they are screwed?
Mine are not and none I have ever messed with are. I am talking about over 30 3rd gens here.
Old Apr 1, 2013 | 06:21 PM
LHernandezJr's Avatar
Old Apr 1, 2013 | 06:28 PM
rawley2's Avatar
What screws? When I take the door card loose I make sure the window is down and tilt it out then off. Never any screws into the top plastic.
Old Apr 1, 2013 | 06:41 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
The inner sweeps are held on by "melted plastic" sort of like little makeshift pop rivets. Just drill them out. Then, re pop-rivet the new sweep onto each top plastic trim.
EDIT: I read inner sweeps...you are talking about outer sweeps.
Old Apr 1, 2013 | 08:22 PM
86TA355SR's Avatar
Yeah, I have done a few of these in the past and never saw this before.
I am talking about the sweeps attached to the door panels. The ones on the inside of the window. Mine screw into the doors.
Motobooks, I'll see what I can do. I tried using a screwdriver bit with a ratcheting wrench and it didn't work. Not enough room.
Old Apr 1, 2013 | 08:33 PM
Old Apr 1, 2013 | 09:08 PM
carlos64030's Avatar
Car: 1991 Trans Am GTA
Perhaps the way the sweeps are attached to the doors varied throughout the years. I remember taking the door panels off of my '91 many years ago with the sweeps still attached to the door panel. In fact, I have a set of absolutely mint '91 GTA door panels with the sweeps attached sitting in a box in my garage.
Old Apr 2, 2013 | 08:11 AM
rawley2's Avatar
Well I have only messed with trans ams but I have never seen them attached with anything to the door.
I have both off my GTA right now and I had to tear the original plastic door liner so I know I was the first to remove them.
Old Apr 2, 2013 | 08:51 AM
86TA355SR's Avatar
I think you may be right, I have done others and never saw this before. First 86 I have attempted to remove them from.
I'll get them out, just being careful because I want to reuse them.
Will try to get pictures and post so everyone can see what I am talking about. Need to get this car out of the garage, great roller, want to get my new GTA I just bought into the shop.
Old Apr 11, 2013 | 09:07 PM
86TA355SR's Avatar
I had to force a screwdriver holding back the window sweep at the same time. I am not re-installing them so I have no idea how you would ever get them back in. And, for everyone that thinks this is something that isn't stock, the screws are factory....strange...I've removed several of these and never saw this.
FYI.
Old Apr 12, 2013 | 12:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Take the whole door panel off,the sill is attached with speed nuts on the reverse side.If you brake them,you can get a new window sill with the sweep attached to it from 1A,I replaced mine when I did the interior over.
http://www.1aauto.com/1A/Weatherstri...SS00097/329666
Old May 4, 2013 | 01:45 PM
wgripp's Avatar
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Does anyone sell the speed nuts individually? Thanks!
Old May 4, 2013 | 03:41 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Ace Hardware has them...but I think they come in small packs..not individual.
Old May 4, 2013 | 04:05 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Maybe Autozone, Oreilys, etc...??
Old May 4, 2013 | 07:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
http://www.clipsandfasteners.com/Thr...ex_p/a3401.htm
Old May 4, 2013 | 08:19 PM
wgripp's Avatar
Not sure if the lip is wide enough on those. needs a 3/16 stud
Old May 4, 2013 | 08:22 PM
wgripp's Avatar
got some at lowes. the lip wasnt wide enough.
Old May 9, 2013 | 01:30 PM
Confuzed1's Avatar
Car: 83Z28 HO
Are the holes in your panel ripped bigger? Maybe you can find a few thin washers?
I know I had an issue with a couple of the prongs on the top rail...they snapped off short when I went to remove the nuts...so...I just put the nuts on backwards!! Yes, it works fine! Once the panel is snapped into place on the door, it was all good.
Old May 9, 2013 | 01:33 PM
Confuzed1's Avatar
Car: 83Z28 HO
I didn't know they had those! That's actually not a bad price since it comes with the upper rail and sweeps...just look at the price of the inner sweeps alone...
Old May 9, 2013 | 07:38 PM
mantaguy's Avatar
Engine: 5.0 EFI
I have a few left,I replaced my sills about a year ago.If you want them PM me.
The small ones are the originals,the other four are from the replacement sills.
RyanJB
Sep 2, 2015 01:27 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
