Spring concern?
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Spring concern?
I finally got the driver side power seat out for upholstry work.
Toward the back end there is a spring on each side. About 1 1/2 " diameter.
Are they under pressure & a concern when taking the unit off the bun?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Spring concern?
Are you talking about these springs,if so, no, their not under any pressure.
Car: '87 Camaro
Re: Spring concern?
Thanks mantaguy!
Anyone suggest what type grease to use for the tracks?
92rsvortec350
19
Oct 9, 2015 09:39 AM
Dragonsys
Sep 25, 2015 03:51 PM
