Turn signal lever wiring help .
Old May 10, 2013 | 02:15 PM
Billyjoebob007's Avatar
Car: 83 Camaro Z28 (CFI)
Engine: 305 V8 (CFI)
Gonna be replacing the turn signal lever, and was wondering were the electrical connector connects to under the dash ? The current lever is unplugged under the dash,can not find were it supposed to connect. What is that for anyway ? the cruise control ? Heres a pic of the connector in question:
http://imgur.com/xJID7C8
Old May 11, 2013 | 01:17 AM
Re: Turn signal lever wiring help .
Soooo, where does it connect to ???
Old May 11, 2013 | 09:01 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
There's a small square connector you'll find under there not connected to anything...that spade goes into there. For whatever reason, the wire from the lever is barely long enough... but it'll go into the connector.
Old May 11, 2013 | 10:23 AM
I do see a connector hanging under there wasn't sure if it was the one. Its got 2 wires, org / wht .
http://imgur.com/LaLr5sE
Old May 11, 2013 | 02:48 PM
Confuzed1's Avatar
Car: 83Z28 HO
That looks like the one, but I can't remember what color the wires were. At least in my case, it's the only stray connector under there that doesn't appear to go to anything.
Maybe someone on the board here has a schematic to ID the wire colors??
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
