Overhead Map Light
Old May 15, 2013 | 08:07 AM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Overhead Map Light
So when I bought this car, the map light was missing. The bulb is there and works, but the swivel part is gone. Even the ring that holds it on was in two pieces in the glove box. I have no idea where to get a new one. I've searched all the sites I know including ebay, and none of the local junkyards ever have Camaros. Does anyone know where I can get new pieces for this?
Old May 15, 2013 | 09:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Overhead Map Light
That you'll find anything new is doubtful. An advert on our site's classifieds might prove useful.
JamesC
Old May 15, 2013 | 02:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Try my82roc,he should have some parts for overhead consoles.
Old May 19, 2013 | 03:45 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Try this: http://www.ebay.com/itm/82-92-Camaro-Firebird-Overhead-Roof-Console-Swivel-Map-Light-Housing-NICE-/321127188731?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AFirebird&hash=item4ac4ac08fb&vxp=mtr
Old May 20, 2013 | 10:14 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
You'll also need the trim piece to hold in the swivel. It has 3 prongs on the rear which fit into your space. Example here:
http://www.ebay.com/itm/82-92-Firebird-Trans-Am-Gta-Camaro-OEM-LARGE-OVERHEAD-CONSOLE-Swivel-Light-/150995942354?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item23280f3bd2&nma=true&si=l%252BsgMyISxR213XeXnhYrPdEfL94%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Old May 20, 2013 | 10:32 AM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
82 92 Firebird Trans Am GTA Camaro Large Overhead Console Swivel Light | eBay
this one is still missing the felt ring that keeps the swivel tight
this weekend i found 2 cars in a junk yard with consoles but all of the parts to them were already gone
Old May 20, 2013 | 11:35 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
i've got the map ball from my for sale ad still
i dont have the ring or gasket though(sold)
as for the felt gasket for the ring, you can make one very easily just buying a sheet of felt from the craft store, cut the size you need twice and glue the two pieces together, it makes for a nice snug fit
Old May 29, 2013 | 05:56 PM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Thanks for the tips everyone. Sorry I got sidetracked these past couple weeks. Caveman, hopefully you still have it. I may just try to glue the ring back together, I can't remember if it's a clean break or if I'm missing any shards.
Old Dec 16, 2015 | 10:16 PM
ramicio's Avatar
Car: '87 Flame Red/Carmine Red GTA
Does anyone have a picture of these pieces of felt? My car came with nothing and the swivel part and ring I bought didn't come with the felts.
Old Dec 19, 2015 | 01:24 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Edit: Forgot this one:
Old Dec 19, 2015 | 01:58 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
Originally Posted by paulo57509
Someone needs to 3D print these like the GTA armrest gasket (top of handle to door) I seen that on here somewhere. If they could duplicate them with a cnc or 3D printer, they could have a lucrative side gig!
Old Dec 19, 2015 | 02:48 PM
ramicio's Avatar
The rings I could see being useful to duplicate, but the ball part is metal, and I just don't see them breaking. What I want to do is put an LED and a lens inside of it to make a somewhat focused beam. Screw trying to track down the original bulb base just to use a crappy incandescent and an aged-yellow non-focusing lens. This may be one of those projects I talk about that I never end up doing, because I can't find the parts necessary to complete it. Lens mounting systems either seem to be 1/2" or 1". The former is too small for my taste, and the latter is too large to be possible.
Old Dec 19, 2015 | 09:37 PM
ramicio's Avatar
Interesting. Thank you. I thought there were two pieces of felt. What keeps it from moving up and down? There seems to be quite a bit of distance between the top and bottom "seats." Almost 1/4". I can see how the felt would stop it from flopping around, but I don't see how it would stop it from being forced up and down.
EDIT: Argh! I didn't see that you edited and added a second picture. That explains my previous paragraph! Wow.
Old Dec 20, 2015 | 01:14 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I put a cree LED from a busted 1157 bulb, extremely bright & creates about a 3ft dia beam.I tried using the cree's lens (looks like a projector lens), but it focused the light to roughly a 6' dia.
Old Dec 20, 2015 | 11:43 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I always learn the coolest stuff here!
Old Dec 20, 2015 | 06:19 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I've gotten the map light bulbs and base from overhead lights in ford explorers.Not sure what years they are but they have a dual light assembly above the rearview mirror.Perfect fit for the roof console
fasteddi
Sep 10, 2015 09:32 AM
andy74
Sep 3, 2015 08:41 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
TheJoeY88
Aug 13, 2015 06:51 PM
Omega
Aug 10, 2015 12:46 PM
