Outer window sweep holes not lining up
Old 05-18-2013, 07:04 AM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
Hi,
As part of my paint job I am replacing the outer window sweeps with really nice ones from Hawks. Only problem is that some of the holes do not line up right. Since the bolts that came out are self-tappers can I re-drill them or is that a stupid idea that will somehow lead to a universe ending paradox?
Old 05-18-2013, 09:03 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Outer window sweep holes not lining up
common problem , when installed at factory they just "eyeballed" & moved down assy. line . install everywhere you can . hot glue may be your friend up front near the "triangle" . worked for me , painted 3yrs. ago . good luck .
Old 05-19-2013, 02:49 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
As said above,seems to be a common problem,some line right up,and some need a little work.
Mine were only off a bit,so I just slotted the holes a little bit.If you have to re drill, it wont hurt anything,just make sure the holes aren't bigger than the screw heads.
Alicat.
Old 05-19-2013, 08:47 AM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
When I replaced my sweeps with a unknown aftermarket brand a couple of the holes also did not line up.
I just punched new holes where needed to match the factory holes.
I also punched and drilled a new hole near the rear of the
door to better secure the end of the new sweeps.
They look and fit just fine......................
Just take your time and measure and test fit TWICE and drill once!
Old 05-23-2013, 03:13 PM
bigtizzles's Avatar
Car: 89 Camaro RS (lawn ornament)
Engine: 327 sbc
Transmission: TH350
Axle/Gears: Stock for now
same thing happened to me. I used some 3m tape in a couple sections in the middle. The holes on the ends lined up.
Old 05-23-2013, 07:11 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
I just drilled new holes.
The factory used self-taping screws that is why they are not the same.
I would not use glue or tape
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
zayne0
08-24-2015 07:22 PM
1Aauto
Sponsored Vendors
08-24-2015 03:40 PM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
Quick Reply: Outer window sweep holes not lining up
