Console swap question
Old May 21, 2013 | 05:05 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
I live in Arizona, a state that is NOT friendly to the later center consoles. I picked up a center console out of a 97 Bird from the yard (Auto). Was going to swap it in but realized that it would require modifications that would not make it possible to just swap it back should I desire. I also notice that the 82-85 Consoles have hard sides, not that vinyl, pleather, or what ever that warped material is on it. Question is, would this console be a direct bolt in to the 88 (by removing the radio pod and center console)?
Old May 21, 2013 | 05:40 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Console swap question
Been covered many many times.
https://www.thirdgen.org/forums/body...sole-tech.html
https://www.thirdgen.org/forums/body...xterior-2.html
Old May 21, 2013 | 06:09 PM
Veaceonee's Avatar
Guess I was misleading. I am wondering if the early 82-84 hard sided consoles would be a direct bolt in.
Old May 22, 2013 | 08:07 AM
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
If you get a manual top to the late model you shouldn't have to do any mods, that's the problem I ran into with my bird being a auto, either a custom top or a manual top.
I can't answer to if a early style will fit though
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
TheJoeY88
Aug 13, 2015 06:51 PM
reiderz iroc
Aug 13, 2015 04:57 PM
