C&C Headliner board - any ideas?
My TA has the C&C T-tops and as things go my headliner disintegrated a decade ago, I've made few amateur attempts at trying to glue/attach various mats/boards to the ceiling and upholster them and while I was happy with my last attempt it eventually just did not last, started sagging etc..
so what is a long time 3rdgen owner to do?
Any idea if a hardtop mat may fit a C&C ttop car? I would of course cut out the holes and reupholster..
What sort of material do custom 'rods use for roofs? How is it on hotrods attached TO the roof?
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: C&C Headliner board - any ideas?
No prob............
Probably any good used stock headliner you will find is gonna be fragile as well as $pendy.
You could buy one of those aftermarket ABS hardtop headliners
and modify it to work with your C&C tops.
I don' think a aftermarket ABS factory style t-top headliner would
work due to the different contours/size/placement of the C&C tops.
morrow
Jan 13, 2024 12:29 PM
I Found the same answer in few threads
