89 FIREBIRD CONSOLE DOOR SPRING
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Anyone have a drawing or photo of how the console door spring is attached inside the rear ash tray compartment and to the lever?
I got Hawks ThirdGen new console lid assembly but mine has been broke for a long time!
Thanks in advance!
Thanks in advance!
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Re: 89 FIREBIRD CONSOLE DOOR SPRING
I would also be very interested in this. Though, my pad is ok, the lever arm is broke out of it and pushed down into the console housing. I've taken the ash tray out and it appears everything is in there, but it doesn't pull up and push down right.
http://www.hawksthirdgenparts.com/pr...roduction.html
You'll have to replace the whole assembly just like I did. The spring is most likely broke as well.
Engine: 4++,350 & 305 CIs
I leave the spring out of my console door. I also took the light switch apart and cut that spring down so it wouldn't hold the door open.
I just don't like how its, to much spring and breaks a bunch of other stuff..
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
How do you get the spring off again? I did this once many years ago. I have to change mine but man what a pain to get the spring off the arm attached to the top. Thanks.
I used a 90 degree flat blade screwdriver and a small hammer to tap it down.
Then you can get the spring off the clip, my spring was broke.
When I put it back together, I put the spring on the lever and slid both through the top of the console where the lever slides up and down.
Once the lever and spring were in the opening where the ashtray was, I connected the spring to the clip and slid it back in the groove.
I put the screws for the hinge (console side) back in. Works like it's supposed to now.
There are two holes in the clip, I used the left hole, less pressure on the spring.
Engine: 5.7
Axle/Gears: Stock
Take the rear ashtray out, frame too. Inside is a clip that slides up into a slot in the rear of the opening.
You're welcome! Have any trouble, just reply.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
ambainb
Apr 25, 2016 09:21 PM
