Door panel rails
Old May 31, 2013 | 07:56 AM
sa1985ta's Avatar
Door panel rails
I recently purchased new door panel rails from Hawks Third Gen for my 1985 Trans Am. This is the black piece at the top of the doors. The driver's side had seven plastic pegs on the back side to attach the door panel to. However, the passenger side only has six pegs. I contacted Hawks and they sent me a new passenger side piece but it has the same problem, only six pegs. Has anyone else had this problem? Six pegs will probably hold the door panel but these pieces are not cheap so I would like to have all seven pegs.
Old May 31, 2013 | 08:54 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Door panel rails
Not sure what you mean by door panel rails? do you mean the plastic piece at the top of the door panel?
Old May 31, 2013 | 10:11 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
They will probably work,BUT,what peg is missing,that's where the problem is.Down the line you might be sorry for keeping them.Tell Hawks to correct the situation or return them.
Old May 31, 2013 | 11:50 AM
jbssbw's Avatar
Car: 89 Formula
Engine: 5.0 tpi
Transmission: M5
I was just going to buy a set when I saw your post. I might order from A1, I see they have a set of both the inner and outer top rails.
Old May 31, 2013 | 09:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
That's were I got mine from,1A.
Old May 31, 2013 | 10:16 PM
jbssbw's Avatar
Car: 89 Formula
Engine: 5.0 tpi
Transmission: M5
How is the quality of there products? Are they gtg
Old May 31, 2013 | 10:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
Good Products,no problems with installing.The inner door sill has the window sweeps attached.
Old Jun 1, 2013 | 03:40 PM
sa1985ta's Avatar
I called Hawks. They checked and found this one peg was missing with all passenger side door panel rails they had in stock. They are going to contact their manufacturer.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
92projectcamaro
Jan 18, 2016 08:00 AM
Out-Cast
Aug 23, 2015 06:33 AM
